Results 1 to 4 of 4
Thread: removing torque converter on a 2t
    Panty Raids 1st year Apprentice rotorat's Avatar
    Nov 2007
    Default removing torque converter on a 2t
    i have just removed the auto of the back of my 2t and i cannot see an easy way of removing the torque converter off the flywheel anyone had experience in doing so?
    Am I getting smart with you? How would you know?
    Oct 2008
    TAS
    Default Re: removing torque converter on a 2t
    often the torque convertor is bolted to the flexplate and u acces the bolts through where the starter motor bolts up.
    no experiance with 2T tho.
    1983 Toyota Celica Supra
    There should be an inspection/access port at the bottom of the bell housing on the block side, pull out the cover and unbolt the torque converter one bolt at a time, spinning the flywheel around to get to each bolt
    I am the sun
    Nov 2007
    cheers guys i got it off through the starter hole
  1. Celica 2T / 2-TG / 2-TGEU / and 3T series engine specs *sticky*
    By toyboyracer in forum Tech and Conversions
    Last Post: 14-07-2010, 08:11 PM
  2. Clutch LSD => Torsen LSD
    Last Post: 21-10-2006, 02:14 PM
  3. fitting new torque converter in 1jz
    Last Post: 14-09-2006, 05:47 AM
  4. Seating f'ing torque converter properly
    By 7mgte mx73 in forum Tech and Conversions
    Last Post: 22-01-2006, 11:27 PM
