Yep - i just checked the Wolf3D V4 user manual:
http://wolfems.com/files/Installatio...457%201004.pdf
.. see page 11.
The Wolf3D V4 is definitely looking for a RISING EDGE zero-cross VR signal. IE, the signal goes LOW first, then high.
I am pretty sure that Toyota VR sensors are FALLING EDGE zero cross.
Therefore you might need to reverse the wiring to the VR sensors. This will probably mean you need to separate the negative wires from each of the CAS VR sensors (the white wires inside the CAS), as they are all joined together. This will be fiddly, but you have to do it.
The WHITE wire from each sensor is therefore the positive VR signal, and the coloured wire is the negative.
Check it on a CRO if you have one![]()
