1. yes with the aw11 4agze it uses a single coil and is easy.. just put the tacho wire (black) on the -ve wire of the coil. the other ones you mention are +ve power for coil.
2. best to fit the sender unit that is designed for the gauge. otherwise won't be accurate.
3. same as above.
4. there should be 2x wires going to the gearbox, usually pretty high up on one side.. red and blue usually are the colours.
