Results 16 to 20 of 20
Thread: 4agze + SC14 = Dissapointing power.
    Jul 2007
    Default Re: 4agze + SC14 = Dissapointing power.
    but, AFAIK cavitation is the formation of air bubbles from a liquid when a pump requires more net positive suction head than the liquid can give. How do you form air bubbles from air?????
    Tallahassee, FL USofA
    What's the compression?
    What's the result when changing the ignition timing?
    Chiba
    Turbulence, not cavitation will occur.
    Also, if you want to retain the stock style idle speed control, a Gen2 3SGTE TB can be used.
    http://www.jdmlevin.com/3SGTEThrottlebodyInstall.html
    Also, do your ABV mod like this:
    http://www.jdmlevin.com/files/NewABVMod.pdf
    Cheers for all the replies everyone. Looks like the poor gze is struggling to breathe.
    Compression is fine, 175 to 180 across all cyl
    Would it be worth getting a 4a/3sgte throttle or just wait and get a later model 3s 60mm throttle and making up a custom 2.5 inch suction pipe and cooler pipes.
    The cooler is to big imo, but it is what the car had when i got it. what are peoples opinions of dual exit intercoolers? I would like to change my over the motor setup if possible to make the piping shorter. What about using something like This put on its side? I would also assume a rwd bigport manifold would be out of the question unless the sc was spaced a fair bit out?
    How easy was it to squeese in a 2.5 inch pipe on the suction side of the sc14. It is quite tight as it is.
    Oh and i have done the abv mod like in the pdf already.
    Past - 3 RA23's 1 TA22 - Hairdresser mobiles
    Present - Red 4age KE70 - Sideways shopping trolly
    Future - White KE70 - Grandma shopping trolly
    Jul 2007
    Quote Originally Posted by allencr View Post
    nice answer douchebag your level of technical input into your response is truly mind shattering
  1. 2TZ SC14 pulley onto 1G SC14
    By Bazooka in forum Tech and Conversions
    Last Post: 16-09-2009, 08:07 AM
  2. 4ag wiring issue, power to ecu but no power out??
    By SLO-055 in forum Tech and Conversions
    Last Post: 16-11-2007, 11:31 PM
  3. 3sGTE Intermitant 30-40% power loss
    By worldwalker in forum Tech and Conversions
    Last Post: 26-07-2007, 05:41 PM
