Page 1 of 3 123 LastLast
Results 1 to 15 of 45
Thread: 22RE.Why dnt they rev past 5,000rpm.
    Jun 2010
    Arrow 22RE.Why dnt they rev past 5,000rpm.
    Hey Guys
    I have a race car with a worked 21r in it and it revs and loves it sitting at 7,000rpm.our rules have now changed (long story) i am allowed to put a 22r in it.i am going to get it machined up and what not but is it the computer that wont let it rev or go any better past 5,000rpm or is it just the motor???
    realy keen to no why
    Default Re: 22RE.Why dnt they rev past 5,000rpm.
    Standard Redline in them is 5800rpm cut use to be around 6200rpm on mine. They are a truck engine and do not like to rev though, power drops off significantly after 5000rpm. My understanding is the swirl intake ports/cam is designed for low end torque and are very restrictive at higher rpms.
    If in doubt power out
    camshaft duration and overlap
    Junior Member Domestic Engineer ill-minded's Avatar
    May 2006
    as above, the head is the biggest restriction (followed by the poopy EFI system) some head work and a megasquirt or carbs will open things up. remember that the longer stroke also restricts the maximum safe revs.
    Junior Member Grease Monkey KENut's Avatar
    Jun 2009
    As said a combination of things, cam, head design, timing, limiter.
    Arguably the biggest change to make would be revised camshaft
    Jun 2010
    ok thanks.this is the list of things im getting done
    Fully balanced
    flat tops and lightened
    2m oversize
    port polish
    bigger valves
    cam
    double valve springs
    bigger injectors
    lightened flywheel
    and when i get a bit more money a stinger ecu.
    That should let it rev a fair bit more hay????
    Got a stinger ECU in the shed you can have for cheap
    -RM
    Nov 2008
    Quote Originally Posted by sumfancyname View Post
    Fully balanced
    2m oversize
    port polish
    bigger valves
    cam
    bigger injectors
    lightened flywheel
    What sort of car you putting it in and what price range you looking at for the engine mods ???
    Jun 2010
    its for a speedway car.a ra65 celica and another is going into my brothers ra60 celica.well that pretty much what i got done to my 21r minus the port polish,lightened flywheel,bigger valves,bigger injectors and i no the engine builder pretty well and it cost me bout $2,600.hoping to be getting 200hp
    Jun 2010
    aww and its going to be on methonal
    So you're going to need MASSIVE injectors
    -RM
    Will the rules allow for an 18R-G... bored and stroked out to 2.4ltrs?
    seeyuzz
    river
    Winner! Actually...what are the rules? Surely there's a more suitable engine? I would have thought even a mildly worked 18R would be a stronger race motor than a worked 22R...
    -RM
    Jun 2010
    ill get heaps heaps more power out of 22r then an 18r.i wld go 18rg but they hard to get and if i need parts for a 22r they are every where
    the only rules are n/a and have to be toyota motor(i cant put a ford motor in my toyota) and have to b 4cylinder.they are open.i was also thinking beams but they are hard to find and get parts for.
    Dunno about heaps more power. Maybe a handful of kWs. Both are uninspiring engines.
    You can bolt a 20R head to the 22R, if that's allowed. This will get you some more power.
    seeyuzz
    river
  1. gtfour celica 3sgte hesitant past 4k???
    By punkture in forum Tech and Conversions
    Last Post: 08-05-2010, 01:55 PM
  2. 1jz wont boost/rev past 3k
    By squish_m8 in forum Tech and Conversions
    Last Post: 12-03-2010, 09:38 AM
  3. 05 Sportivo: Won't rev past 3,000 RPM
    By unleashed__ in forum Tech and Conversions
    Last Post: 17-06-2007, 03:17 PM
  4. V8 Soarer Won't rev past 3800RPM
    By Buttocks in forum Tech and Conversions
    Last Post: 07-09-2006, 08:57 PM
