Page 1 of 4 123 ... LastLast
Results 1 to 15 of 53
Thread: V8 Soarer Won't rev past 3800RPM
    Jun 2006
    Default V8 Soarer Won't rev past 3800RPM
    My Fathers new V8 soarer (he's 62) won't rev past 3800RPM its not a big problem as he still hasn't sold his last car and isn't driving the Soarer yet. But anyone had a similar problem, and what did ou do to fix it?
    Default Re: V8 Soarer Won't rev past 3800RPM
    Check all the main things dude.
    Fuel, spark, exhaust blocked, intake blocked.
    Is it smooth as at idle?
    What does it do at 3800, just hold there like a rev limiter, or hunt?
    More details
    Jun 2006
    Like a rev limiter. its completely perfect in every other way. So its a computer fault or something, as its 3800 in every gear i checked
    Unplug the TPS and try it again.
    Jun 2006
    I'll give that a shot tomorrow arvo
    Check for error codes on the ECU, sounds like it might be some sort of "limp home" safety mode.
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    Failing any of these suggestions your best bet would probably be to take it to your friendly toyota dealer. They should be able to diagnose it pretty easilly.
    Once they tell you whats wrong with it buy the parts required off the forum
    Jun 2006
    i'll figure it out by myself Thanks. Its always something simple and you guys have give me some ideas
    Also check that the timing isnt locked. I had this a while back in my GZE where i forgot to pull out the timing lock short after timing it. Wont rev past about 4000rpm.
    Viagra Enlarged Member Grease Monkey TRAV-KE55's Avatar
    Chech that the engine hasnt been washed and filled the plug holes in the heads up with water, the water then wicks up the leads and gets a wet tracking down past the plug to earth. Seen it a few times on these V8's
    Have a nice day.
    Trav
    Active Corolla abuser!!!
    Travis Robson
    0418 552 413
    could be air flow meter make sure there are no air leaks in induction
    did u change gearbox or do anything just before this happened
    there are a number of things that make the engine not rev out
    does it still try to rev up thru the problem even when u keep it floored
    or is it rev limiting at an exact rev
    could also be throttle cable. I had this problem with my ma70.
    Junior Member Carport Converter 4agte's Avatar
    could also be a melted/blocked cat
    Junior Member Backyard Mechanic ndgcpr's Avatar
    interested to see if you figure it out. we had a 1J with the same issue. changed quite a lot of things to try and fix it. the guy ended up reving it up and boosting at free rev (because it didn't limit in N) and the motor started making bad noises so we may never know...
    Noisy Diff and Gearbox Club of Pine Rivers
    and you thought your car was loud
    The Soarer brought to you by the letter TT
    The 1UZ-FE in the Soarer's rum MAP sensor as well air air flow meter. Just check to make sure the MAP sensor is still connected. Top LH on intake plenum.
    cheers Chuck.
  1. Dash error codes on Jzz30 Soarer
    By RLR in forum Tech and Conversions
    Last Post: 25-03-2006, 04:38 AM
