Results 16 to 22 of 22
Thread: what to consider when changing a clutch
    Default Re: what to consider when changing a clutch
    Quote Originally Posted by Big rob
    well its definatly 6 bolt otherwise no idea how its holding on there. What about a 1jz? WHats there flywheels like?
    1jz = same as 2jz, 8 bolt.
    I was under the impression that M series flywheels didn't fit due to the M series offset hole (my memory might be wrong). Anyone?
    Junior Member Automotive Encyclopaedia Big rob's Avatar
    well anyway its 9.5", i was quite suprised actually as i thought it was 9.25" like 1ggte flywheel but when i took it to the clutch guy for some reason the pressure plate wouldnt fit on the dowles, i wonder why lol
    Long Time Reader Backyard Mechanic willwal98's Avatar
    hey anyone want to give me some pointers on changing the spigot bearing? I was thinking maybe some kind of slide hammer or something because that thing is in there tight..
    Also the rear engine seal, is it just a matter of digging it out and tapping the new one in like all other cars i've done?
    BTW this is for a 1g-gte.
    ta
    There was a big thread on spigot bearing removal techniques only a few weeks ago, with almost everyone having their own method. The most commin is a hydraulic method, filling the space behind the bearing with grease, or wet paper, or soap, or some left over dog food, and then inserting something that's a tight fit into the the centre of the bearing & squashing it all in, then repeating, until the chosen medium forces the bearing out.
    BTW, don't use dog food.
    I think the winning method was plasticine!
    Gen2 1GGTE flywheel is 9" and Gen3 is 9.5"
    so stuff the end of the crank with plastacine and belt in a piece of wodden dowel that is the right size. Sounds doable. Will playdough do?
  1. Clutch LSD => Torsen LSD
    Last Post: 21-10-2006, 02:14 PM
  2. AE86 Clutch Help
    By Trizae in forum Tech and Conversions
    Last Post: 20-04-2006, 11:08 PM
  3. Grease on flywheel / rear clutch surface..wtf!
    Last Post: 27-03-2006, 12:14 PM
  4. W58 7M-GTE clutch choice
    By RyleyMA61 in forum Tech and Conversions
    Last Post: 03-02-2006, 07:57 PM
