It states that the SS girdle doesn't come with the caps oldcorollas. I think $1500 is reasonable for something of this complexity which they have obviously put a lot of time and effort into designing, choosing the correct material, testing and manufacturing. It not as simple as a flat plate with holes in it. There are protrusions/recesses for the caps to meet flush as well as possibly a few other hidden bits that would need to be taken into consideration. I just honestly believe if someone was to have one custom made the cost could quite quickly blow out past $1500. For instance a custom intake plenum, a good one is at least a grand and there isn't much if any machine work in one of those, its the labour that's the killer, if someone had the skills and time plus access to the right gear maybe then it would make economical sense to build your own.
			 Re: 4age Crank Info for 4agte usage
