this is probably pointing out the obvious to yourself but at those revs you need to shim your pump to have higher pressure.
 Re: 4age Crank Info for 4agte usage
				Std Rods and Std GZE pistons.... on my new engine the only thing that is going to be changed are the rods as my rpm is getting up there now. Im basicly cutting the power at 9k.... It would make more power if i let it rev further but im not too sure on how much further i can go
Allencr: Crank is std size journals. I wouldnt hesitate on using a undersize crank...... depends on how far undersize it has been ground ,but in moderation..... no wouldnt have an issue with it.
				My bottom end has definitely ended up as overkill then! New crank, spool rods, Aries pistons, and tossed the underground crank, not because I didnt trust the crank I just dont trust any other shells than ACL race series.
				King are good... i've been told personally that ACL aren't all they're cracked up to be.
+1 to std gze slugs, does anyone know how many are left in stock over in japland?
				Geez we cant win mate, you got told "personally" as did I that ones crap the other gold....two different brands??? Gotta trust your man who's doin the tricky bits for you in the end (machinist)
Gze slugs...price em NOW.. if my cranks anything to go by you may be onto a winner!!
				he doesnt need to price them. i can tell you
$500
				hehehehehe.... found some interesting bottom end info recently.........
1) shotpeen the main caps....
2) check around... most times a 4A crank breaks, it is either @ the 2nd main, or the 4th main. Hasselgren would machine the block skirt @ these 2 mains, and then add a hardened strap across main # 2 and #4 and they would be tied into the block walls! No other straps, or reinforcement was needed.
				good to hear man!
				Split bores! Doesnt sound funlol...
