Page 3 of 11 FirstFirst 12345 ... LastLast
Results 31 to 45 of 152
Thread: 4age Crank Info for 4agte usage
    May 2010
    TAS
    Default Re: 4age Crank Info for 4agte usage
    Any more details?
    Here is the information I was given as per their rods and crank:
    "As you see,*our rods*quality*is same level with*top brands such as*Arrow or Carrillo. The rods are floating pin (bushing pin) and they can run with 9000rpm & 800HP with ARP 2000 bolts. They or will run over 12000rpm & 1000HP with ARP L-19 bolts. Our billet cranks are crossed drill from OEM, much lighter and stronger than OEM. The quality is same as Tomei or Cosworth. They can hold out 800-1000HP (max 18000rpm & 1800HP). All of our parts have passed high standard inspection and well balanced."
    Apr 2008
    My computer tells me the above website has malware....
    Wow, a whole youtube scene on cranks. Forged vs cast - tap test
    http://www.youtube.com/watch?v=8dA1A...eature=related
    and the mother of all cranks...
    http://www.youtube.com/watch?v=taMV8...eature=related
    I do get that on one browser and not on another I will report it back to the rep
    I found out this which was reported by the company "Furious Racing Parts(FRP) Company is professional High performance parts Manufacture which is established at 1988. We specialized in high performance parts for various engines, which is include 4340 EN24 Billet crankshafts, 4340 H-Beam Rods, Roller lifters, and Turbochargers. All our parts manufactured by advanced CNC machine and pass high stand inspection. We also offer OEM service.
    FRP has built a reputation as one of the leading manufactures of racing parts for high performance engines. Our each part is a precision, high strength, quality piece.
    We also can custom rods and crankshafts to suit your application. Our engineers are available to discuss your requirements if you are unsure of exactly what you need."
    I did some research and it seems that people like the price but not one person wants to try them out as they are worried its just a scam site
    May 2010
    TAS
    Haha musical cranks. The forged resonates at a much higher pitch and for a lot longer, the cast crank sounds very dull, says a lot about the difference in the grain structure.
    So who's got a loose 4age crank and hammer spare???
    May 2010
    TAS
    This was another forums experience with furious, when they asked for more info than just a name "tony" and an email address it seems they had no reply. I also get attack and malware messages. Very skeptical now.
    http://forums.nasioc.com/forums/show....php?t=1746764
  8. #38
    I am likely going to try their cam gears, I know someone who has a friend with them and they seem ok. If the gears seem ok after my testing I will see.
  9. #39
    May 2006
    tas
    Quote Originally Posted by Sam_Q View Post
    I havent seen the confusion you speak of, they are definately forged from the markings. I have a company that wants my buisness to be a reseller of their products and they are offering a 4340 aftermarket crank for about $1200. I am wary of it though without researching it though
    they contacted me as well. i was talking to you ages ago about them but they couldnt give any specific info. dont think they are much chop
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
  10. #40
    the picture you showed me a few years ago had thin webs and I would trust them at all. Knowing they are reportedly from the same company worries me.
  11. #41
    Twisted ****** Backyard Mechanic .T.'s Avatar
    fyi i have only seen one broken crank in the flesh & that was out of a aussie ae93. cracked right through the 4th journal. motor still ran surprisingly. I stripped the motor for parts - but i did not look at the break unfortunately to see if it was caused by an inclusion.
    there was a clubman in nsw a few years ago with a hot motor that was breaking cranks as well - ironically the problem was apparently fixed by fitting a very stiff cast alloy sump. must have been some weird resonant frequency that the motor was being revved too. (fyi try holding your 4age to around 4100rpm & see how much stuff in it vibrates - rear vision mirrors etc)
    T
  12. #42
    Sep 2009
    where do i get one of these sumps?
  13. #43
    May 2006
    tas
    heard about these clubmans using alloy sumps and them causing crank breakage.
    Sam, why can this company not show there parts in action? if they truely are as good quality as tomei and cosworth then why cant they show anything to back them up? surely if people are going to be so skeptical then they would sponsor someone, or even have more info on there RnD program, a video of there parts in action on a engine dyno etc. this leads me to believe that these are just another chinese part that has just been made to look like some other brands part.
    i dont discount all chinese made parts, due to the tight arseness of people, trust make there LS range off intercoolers/oil coolers in china to compete with the chinese made brand products. still not as good as there other japanese made ones.
    -JZX83 in the build
    <3 7M sludge pump
  14. #44
    casey,
    sumps were made by prb in greenacre - very hard to get hold of. pm me & i'll tell you of something else you can use
    T
  15. #45
    Oct 2009
    I recommend one of these if you want a forged one
    http://www.trademe.co.nz/Browse/List...x?id=311547671
    Last Post: 17-06-2008, 08:53 PM
  2. 4AGZE in to 4AGE AE82. (now with CV shaft info)
    By Striker in forum Tech and Conversions
    Last Post: 28-12-2006, 02:53 PM
  3. Info Needed: 4age FWD Throttle Cable
    By GTZLevin in forum Tech and Conversions
    Last Post: 28-06-2006, 03:40 PM
