Results 1 to 8 of 8
Thread: what clear oil to use in boost guage?
    Perth, WA
    Default what clear oil to use in boost guage?
    just found out I got a liquid filled boost guage but most of the damper oil in the guage has leaked out.
    I was wondering if I am going to refill the damper oil, what type of oil i can use? Has any one done it before?
    Default Re: what clear oil to use in boost guage?
    I am not sure - but I would ask these guys:
    http://www.howardinstruments.com.au/
    Tallahassee, FL USofA
    Glycerine, also called glycerol
    Sep 2009
    Quote Originally Posted by allencr View Post
    This man speaks the truth!
    Perth, WA
    yeah I just found out cooking Glycerine in supermarket can be use :-)
    another thing is, it is a 0-35psi boost guage. which means no vacuum reading. If I am going to use it in a normal conventional turbo gasoline engine, will the vacuum at idling/no boost will destroy the mechanical in the boost guage?
    Jul 2007
    no, it just wont show anything till you hit positive manifold pressure
    If your worried about damaging the gauge with vacuum, just plumb it into the piping before the throttle instead of in the manifold. That way there won't be any vacuum anyway.
    Junior Member Backyard Mechanic maurice c's Avatar
    Yes we Canberra
    You;ll find that on the shelf in woollies, around 7 dollars I think, medical section.
    Getting your missus to help bleed the brakes isn't everybody's idea of quality time.
  1. Sub 10$ knock detector. (3SGTE and maybe others?)
    By OnAll-FOUR in forum Tech and Conversions
    Last Post: 22-01-2009, 09:58 PM
  2. Hybrid Boost Controller Installation
    By doobs in forum Tech and Conversions
    Last Post: 31-03-2007, 02:19 PM
  3. Trying to wire up solenoid valve to boost controller?
    By trd-st162 in forum Tech and Conversions
    Last Post: 21-11-2006, 09:35 PM
  4. TA63 boost spike problem
    By Diz44zy in forum Tech and Conversions
    Last Post: 28-01-2006, 12:44 PM
