Results 16 to 20 of 20
Thread: Upgrading Alternators - Amp Ratings?
    Default Re: Upgrading Alternators - Amp Ratings?
    Quote Originally Posted by sil80 1J View Post
    do fuel pumps draw more current as rpm increases?
    Additional load is placed on the pump as boost increases but this is not proportional to rpm, so no. I would assume that the power draw from this extra load is marginal. Generally alternators produce more current as rpm increases, so its very strange you are losing voltage as rpm increases.
    JZA70|R / 12.45 @ 111 mph.
    where is the voltage being sensed from? perhaps it is the "ground" that is increasing, rather than the alt output voltage decreasing
    Professional Amateur Grease Monkey sil80 1J's Avatar
    Feb 2008
    i am yet to investigate the problem, i was more interested in alternator outputs from various engine variants so as i could make the decision to go to another alternator or rebuild mine
    the earth issue is a great point, everyone gets so tied up in sender wires they rarely put much thought into the grounding of the device, i was pretty generous with my grounding but another look will not harm anything
    Sil80 1JZ chasing 400rwkw
    Update: 4/5 the way there on 21 PSI, 350.3rwkw
    http://i112.photobucket.com/albums/n...L801copy-1.jpg
    if you can, measure voltage from the alternators output post to the case of the alternator.. if that is stable, you have wiring issues
    how old is the battery? could it be having issues accepting current?
    Feb 2008
    Quote Originally Posted by oldcorollas View Post
    at idle or when im getting the loss?
    battery is ok, not that old, what makes me rule out the battery iis the voltage is good at idle, is a coil pack is on the way out could it cause extra draw as it struggles to ignite?
  1. Upgrading Injectors - 440cc - 660cc - with programmable ecu
    By Kedderz in forum Tech and Conversions
    Last Post: 02-04-2010, 04:42 PM
  2. Help wanted: 1g alternators info?
    By Gttwinturbomk3 in forum Tech and Conversions
    Last Post: 28-04-2008, 03:14 PM
  3. 3TGTE cams - worth upgrading if using mild turbo
    Last Post: 19-11-2006, 01:55 PM
  4. torque ratings 3sge gen2
    By sam-131 in forum Tech and Conversions
    Last Post: 29-10-2006, 09:04 AM
  5. Upgrading 1JZ alternator
    By beasht in forum Tech and Conversions
    Last Post: 19-01-2006, 08:28 PM
