Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
Thread: 2jzgte > w58 possible non carnage
    Not in the diner Alf! Conversion King RyleyMA61's Avatar
    Default Re: 2jzgte > w58 possible non carnage
    my 7MGTE is cranking out a lot of torque and while the w58 has complained when i abused it, since then been all good.
    peewee is dead right, make your weaker point the clutch and not the box, so if anything gives, the clutch will
    Quote Originally Posted by pandaah View Post
    also doesnt look like they make a PPG gearset for the R154... spewin
    few OS Giken ones still floating around for the r154.
    Also dont load up 5th gear with heaps of torque up a hill as you may remove the teeth from the gear
    May 2006
    tas
    i have been doing a little research into clutches today.
    OEM GTE vs GE clutch specs
    Plate (mm) 250 - 236
    Pressure (kg) 1060 - 700
    these are the two clutches that im looking at
    http://www.kudosmotorsports.com/cata...zge-p-621.html
    normal HD clutch^^
    http://www.kudosmotorsports.com/cata...zge-p-622.html
    cushion button clutch^^
    im thinking with the lower clamping then the standard GTE clutch that the normal HD is very possibly going to just slip under high load. so im leaning towards the cushion button as that should hold toque better. according to that site its still considered to be street-able for a daily driver which the car is intended to be.
    anyone used exedy cushion button?
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    i run a w58 behind my 1jz in an ra28. It has roughly 350rwhp and no worries whatsoever. If you're going to go the w58 gearbox, remember that you have to get the "hens teeth" bellhousing to bolt to the 2jz, and with any decent amount of hp a decent clutch. Luckily for me i bought mine as is so i didn't have to go hunting for those bits. I've seen w58's with 2j bellhousing advertised at the $1000 mark and more! I'll be reshelling my 28 over the next year and i'll be getting rid of my w58 as i scored a FREE r154
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    May 2006
    tas
    thanks for the post ben.
    bellhousing isnt an issue to find, im ordering a new one most used ones are more then a brand new one anyway! w58 or 55 are not that expensive or hard to find, i think these a place that sells reco'd ones for about $500 aswell if i got desperate.
    found a few options for clutches now, NPC especially have been really helpful and there prices are great too!!
    just debating which clutch, there is a 1300kg organic from NPC or 850kg cushion button by exedy
    -JZX83 in the build
    <3 7M sludge pump
    Roadkill, you need to remember your car is significantly lighter than a cressida, which I'll assume is the car he wants the box for. You'll find this is a big factor in how long your box will last compared to his.
    May 2006
    tas
    while this is true, varients been used in 2wd Hilux for decades and im sure they have been able to pull many loads. mx83 are about the same weight as jza80.... but yes fair bit more toque there. im confident that the box will be fine with the stock motor.
    oh and as well as plenty of engines with more power then im going to be putting threw it, not really concerned about the box strength now, more sorting out exactly what clutch ill use.
    -JZX83 in the build
    <3 7M sludge pump
  1. W58 Version Comparisons
    By medwin46 in forum Tech and Conversions
    Last Post: 06-03-2019, 09:02 AM
  2. Can i swap 3rd gear from W55 into W58?
    Last Post: 28-04-2010, 08:12 PM
  3. Verifying a w58 gearbox
  4. W58 into TA22
    By fade-e in forum Tech and Conversions
    Last Post: 26-07-2008, 02:42 PM
