Results 16 to 30 of 37
Thread: 2jzgte > w58 possible non carnage
    Default Re: 2jzgte > w58 possible non carnage
    Are they JZ R154's or 7M?
    yes you... i dont intend on using sticky tyres. the pressure plate is stronger then a normal uprated HD one?
    It's a custom NPC clutch and pressure plate. Not sure on the actual clamping force, but somehow the clutch is able to withstand ~500ft lbs of torque.
    Aug 2009
    what are the PPG gearsets rated too in horsepower does anyone know, cos if so id like to keep my w58 and put the PPG gearset in and run the 1.5jz up to 800hp......
    obviously this project will be continuing for years to come just wondered how much abuse the PPG set can take
    May 2006
    tas
    how much is that gearset though? thought it was around 6k?
    while i have this kettle of fish on the boil. the w58 will fit in a normal mx83 trans tunnel without bashing? as GX81 came with w5* from factory..? but r154 will need a heap of flogging.
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    Aug 2009
    AFAIK the w58 and R154 fit without tunnel bashing.. and the V160 just doesnt fit, maybe with tunnel chopping/modding....
    i think
    Aug 2009
    also doesnt look like they make a PPG gearset for the R154... spewin
    R154 needs a bit of tunnel bashing in a Cressida to fit.
    Not as much as most cars though.
    Quote Originally Posted by Scoobzd View Post
    They have in stock 2 x R154s @ $950 ea.
    Expected this to be too good to be true... oddly enough rang them, they don't have stock of R154, only jza80 non turbo (ie... w58) - lo and behold, for $950 each. Said around 1200 for r154 when they do have them
    May 2006
    tas
    yeah that would be right ^^
    IF they do have JZ r154 for $1200 that is still cheap. i dont know how they could actually sell them at that price and make money though.
    -JZX83 in the build
    <3 7M sludge pump
    My mate has bought 2 R154's in the past - one was just the box and it was $1500 delivered from the states (off ebay), the other was around $2500 from the toy shop in newcastle - but this was a full JZZ30 conversion kit including tailshaft, clutch, pedal box, lines, master cyl, etc.
    As Bananaman said the wreckers here only want $1200 - so, since they probably source them from Japan howcome it is so hard to find one for a cheap price when you're at the source?
    May 2006
    tas
    its hard to find one cheap at the source because they are not cheap anymore. 12months ago they where selling for around ¥45,000-¥60,000 now they seem to be going for ¥70,000-100,000.
    there is one on ebay australia for $1800 buy it now, prob not such a bad price but doesnt look to come with any other bits.
    there was one just recently that went from ¥12,000>73,000 in the last few hours. all others have high starting prices. however im watching another low starting price one at the moment.
    -JZX83 in the build
    <3 7M sludge pump
    There is a seller (wrecker) on ebay who has had a few at the 13-1500 mark, in adelaide. Was only recent
    Junior Member Grease Monkey BEVANI's Avatar
    Apr 2008
    The one for the W series aint cheap $8250 and an ETA of 12 weeks
    If in doubt, drift her out! Steer from the rear! less traction,more action! simple!
    BURN RUBBER
    ░░▒▒▒▓████ JZA61 FTW!
    May 2006
    tas
    maybe for a brand new w58.... we are only talking about buying the bellhousing new here and using a used box. well at leasat i am.
    -JZX83 in the build
    <3 7M sludge pump
  1. W58 Version Comparisons
    By medwin46 in forum Tech and Conversions
    Last Post: 06-03-2019, 09:02 AM
  2. Can i swap 3rd gear from W55 into W58?
    Last Post: 28-04-2010, 08:12 PM
  3. Verifying a w58 gearbox
  4. W58 into TA22
    By fade-e in forum Tech and Conversions
    Last Post: 26-07-2008, 02:42 PM
