Results 1 to 12 of 12
Thread: Problem starting 2JZGTE
    Junior Member Grease Monkey teamdrinkalot's Avatar
    Aug 2006
    Default Problem starting 2JZGTE
    Lately when I start the engine, it runs on approx 4 cylinders, belts out lots of black smoke until I give it a couple of good revs then all is well. I have changed the plugs - still the same.
    Another interesting thing is that if the engine does not fire 1st go, it takes a lot of cranking the second time to fire it, sometimes to the point of nearly flattening the battery.
    May 2007
    Default Re: Problem starting 2JZGTE
    is it a standard 2jz with standard ecu and loom or aftermarket?
    ide be checking
    idle control valve
    map sensor
    crank and cam sensors...
    in that order
    when you say running on approx 4 cyl how are you determining this? low idle/almost stalling?
    Question Re: Problem starting 2JZGTE
    i would start by checking the injectors. the may be leaking residual pressure from their last cycle and in return making it run on four on startup due to being flooded.
    MX83 Grande 1jz GT35R buildup here.
    http://www.toymods.net/forums/showth...ghlight=grande
    Some say that his heart has 6 cylinders. All we know, is he's called,
    Aug 2006
    Quote Originally Posted by midnight_purple_GA70 View Post
    ide be checking
    idle control valve
    map sensor
    in that order
    Yes it is all standard. And not running on all cylinders by the sound and the un-smoothness of the engine.
    Brisbane
    Perhaps it's a BHG?
    Seriously though it is overfuelling, check that your injectors are earthing correctly.
    Junior Member Backyard Mechanic manny's Avatar
    I'd suspect the EFI ECU - our 1UZ used to behave in a similar manner until the ECU was changed.
    GSE20 IS250 - daily
    Dec 2009
    check your coils... had a mates that wen the coils were cold the motor would only fire on five cyl till the motor warmed up than it was fine... just a thort...
    May 2010
    Moscow
    Which errors are present? A lamp from W terminal to +12V with TC terminal grounded.
    Dec 2009
    thanks guys all is sorted running fine so far
    thanyou for all help
    untill next time
    what was the issue?
    Dec 2009
    mainly just the pinout wiring
    so many diagrams out there just had to get the right one but with the help of the other members input i got it all in the right spot now and is going fine
    Aug 2006
    All fixed after ECU change.
  1. 4age 16v apparent cold start problem - solved
    By Chrisso in forum Tech and Conversions
    Last Post: 22-05-2010, 11:19 PM
  2. 2jzgte into a gx61
    By ryanfels in forum Tech and Conversions
    Last Post: 18-10-2009, 09:02 PM
  3. 2JZGTE VVTi wiring diagrams and ECU pinouts
    By 98SZR in forum Tech and Conversions
    Last Post: 02-07-2009, 12:55 PM
  4. A340E transmission problem
    By PlacentaJuan in forum Tech and Conversions
    Last Post: 11-06-2009, 09:55 AM
  5. MZ20 Soarer starting problem
    By whatthe? in forum Tech and Conversions
    Last Post: 05-03-2006, 06:19 PM
