Results 1 to 7 of 7
Thread: coolant temp sens/switches around M15x1.5 size??
    Penrith BC
    Default coolant temp sens/switches around M15x1.5 size??
    heya...
    have a Nippon Denso oem radiator here with a 15mm (or so) sized hole in it i need to fill ( just plug it up really)
    i assume it was a thermo switch for the fans, or a temp probe, but really dont know, or have any way to find out.
    all i know is that its looks about M15x1.5 (though could be something else...
    ...does anyone know what that common size is likely to be?
    i dont have a bolt shop or industrial supply place here, so cant just go check out a few threads and see what fits. im hoping that theres a common sized probed/whatever that will go in that hole?
    and if there is one, AND you have a psare, reckon you could sent it to me in the mail??
    thanks!
    ed
    ../delete/ban
    tech moderator
    Default Re: coolant temp sens/switches around M15x1.5 size??
    No such size as 15x1.5 most likely 16x1.5 . Do you need one with an O ring seal?
    Jealousy is a curse
    Not in the diner Alf! Conversion King RyleyMA61's Avatar
    yeah madmont is right, M16x1.5. Will check bolt box today and get back to ya
    do u want a switch or a sensor?
    tridon switch catalogue here http://www.toymods.org.au/forums/sho...ghlight=tridon
    Penrith BC
    yup, i had another look, m16x1.5
    and yer, looks to needs an o-ring seal by the look of the face. although some loctite usually fixes that kind of problem
    rob, dont need 'anything' other than the right sized doover to fit in the hole. kinda dont even have a bench or vice to go buy a bolt and cut it down at the moment! so yeah, if anyone has a bolt bucket with a spare floating around in it? awesome.
    ill also check eghey
    ed
    ../delete/ban
    tech moderator
    Penrith BC
    all good, i think ive got something sorted here!
    cheers for the correction on the m15 vs m16
    i have so few tools here, appreciate the help
    ed
    ../delete/ban
    tech moderator
    cool sing out if you need one coz i found a dirty old one i can clean up and send to uberland if ya want
    ps. find some pre-merger (with mercedes) amg stuff for me
  1. Thread size on a stock 1ggte water temp sensor?
    Last Post: 15-11-2007, 11:33 PM
  2. coolant temp sensor
    By VasH in forum Tech and Conversions
    Last Post: 01-08-2007, 06:10 PM
  3. Temp Issues, ST162
    By doobs in forum Tech and Conversions
    Last Post: 26-06-2007, 06:56 PM
  4. 2JZGTE Engine Coolant Capacity? Aristo...or Supra
    By sbyder in forum Tech and Conversions
    Last Post: 08-03-2007, 08:08 PM
  5. Coolant Temp Sensor
    By druu in forum Tech and Conversions
    Last Post: 15-09-2006, 05:19 AM
