NVM, found out its around 9-10litres![]()
				I flushed my radiator out last week. I filled it up with having the heater on full blast, waiting for the thermostat to open, topping up again and then going for a drive and topping it up again. Initially I put in around 6 litres. The next day i went for another drive and it needed another litre put in.
Went for another long drive, coolant got up to 105degrees, pulled over and put in another 3 litres of coolant. Drove to work this morning and it needed another 500ml of coolant. FYI, the greddy temp sensor i have is in the top radiator pipe.
There was leaks, but that has all been fixed when i put the radiator back in.
There is no water in the oil, no smoke out the rear and the engine is running as per normal. I dont think the motor is getting hot, just its running out of coolant causing the temp gauge to go up. There is no leaks and the thermostat is brand new and radiator just flushed.
What is the approximate coolant capacity of the cooling system for a 2JZGTE?
Apart from it just having air-pockets and me having to fill it up 4 times, i cant see a reason for my lose of coolant.
Thanks
Ben
yep, mine is 9 litres (plus overflow bottle) with a Cressida Radiator.
