Results 16 to 30 of 40
Thread: Can't raise boost?
    Jun 2009
    Default Re: Can't raise boost?
    ohhhhh i read again.. u will have the biggest air leak in 1st because of the amount of strain the car is under it will pull more. like mine.. i think u buggered up the MBC lol.. turn it the other way lol
    90' GT-Four ST185 RC motor ST205 gearbox!
    New installs Ct20B and Rear Strut Brace!!
    Next to come;
    3SGE cams, Fidanza Adj Cams, WolfKatz fuel rail!!
    Junior Member Grease Monkey codez's Avatar
    Aug 2009
    haha okay thanks mate, i thought i was doing it the right way though because i am hitting 10 psi now and on stock boost i was only hitting 8 until i wound it out?
    ill try winding it in and see what happens
    ive also been told on z20soarer.org that it may be my bov letting the pressure out at a certain time which can be adjusted...
    Aug 2009
    i just wound it in and tested it and im getting less boost now (8psi)
    so i must of been doing it the right way..
    can anyone connfirm the theory of the BOV letting out the air at a set pressure?
    yes bovs can leak.
    block it off and see if its the problem.
    RA23 - Twincharged
    JZZ20 - Daily
    Aug 2009
    block off the line that joins it back to the manifold?
    and with what lol
    sorry im a noob..
    rubber stopper and a o ring clamp or something suitable to block the holes off once you remove the bov to not allow any airleaks
    RA23 - Twincharged
    JZZ20 - Daily
    Aug 2009
    ok cheers
    my bov is adjustable so would it be easier to just adjust it and see if it makes a difference?
    if its leaking, its doing so unpredictably, by removing it and blocking up the holes your testing to see if it is the cause of problem or if its somewhere else.
    RA23 - Twincharged
    JZZ20 - Daily
    It sounds like maybe you shouldnt raise the boost if your a newb.....
    Aug 2009
    I'm asking for help not criticism.
    So what im new to turbo cars and dont know how to test for certain faults..
    "ToyMods provides a friendly environment for Toyota owners and enthusiasts in which they can learn how to modify their car and improve their automotive skills."
    I'm young and I'm just trying to learn and ask alot of questions to make sure i don't make a mistake if I can avoid it.
    Quote Originally Posted by codez View Post
    See post above yours
    Aug 2009
    yeah?
    I don't necessarily want to run more boost, but I want to know that I'm able to if I choose to.
    It bugs me knowing that there is a problem on my car and when its fixed and I'm able to raise boost I won't be setting it at stupid levels or anything like that anyway.
    Mar 2008
    inner west syd now!
    Quote Originally Posted by Kedderz View Post
    If you have a leak you should be able to hear it sucking in the extra air, also being a AFM metered car, it will run rough due to the extra air being sucked in after the AFM.
    this will only happen IF the leak is obvious, if its a loose clamp it will be loosing boost but not sucking air off boost, the problem is the more boost your running through a loose clamp the more boost it will bleed, so it is quite possible the turbos are making 20psi, but because the clamp is leaking boost its only actually getting 10 at the manifold!
    Jun 2009
    Thats strange that it gave you less boost.. maybe its not a ball and spring lol..
    Actually my BOV is leaking atm too.. adjust it to the tightest setting tape it up, block it off.. whatever.. JUST WIND THE BOOST DOWN lol..
    if your BOV is venting to atmosphere it will cause you trouble with the AFM, youll back fire and splutter. hopefully its recirculated back into the intake..
    its a steep learning curve i know.. youll get use to it and then you can pick on the noobs lol..
    Next to come;
    Brisbane
    Quote Originally Posted by woggin View Post
    you're wrong, if it's flow metered and you're losing 10psi then it will be running rich as a motherfucker
  1. Implementing a form of closed loop boost control on Wolf v500 ECUs
    By OnAll-FOUR in forum Tech and Conversions
    Last Post: 08-10-2009, 06:33 PM
  2. 2jzgte - strange surging boost when cold
    By PlacentaJuan in forum Tech and Conversions
    Last Post: 15-04-2008, 10:56 AM
  3. Hybrid Boost Controller Installation
    By doobs in forum Tech and Conversions
    Last Post: 31-03-2007, 01:19 PM
  4. Trying to wire up solenoid valve to boost controller?
    By trd-st162 in forum Tech and Conversions
    Last Post: 21-11-2006, 08:35 PM
