Page 3 of 3 FirstFirst 123
Results 31 to 40 of 40
Thread: Can't raise boost?
    Junior Member Grease Monkey codez's Avatar
    Aug 2009
    Default Re: Can't raise boost?
    Quote Originally Posted by TRDcelica90 View Post
    Thats strange that it gave you less boost.. maybe its not a ball and spring lol..
    Actually my BOV is leaking atm too.. adjust it to the tightest setting tape it up, block it off.. whatever.. JUST WIND THE BOOST DOWN lol..
    if your BOV is venting to atmosphere it will cause you trouble with the AFM, youll back fire and splutter. hopefully its recirculated back into the intake..
    its a steep learning curve i know.. youll get use to it and then you can pick on the noobs lol..
    okay mate ill give that a try tomorrow, cheers
    yeah my BOV's recirculated to the intake
    Mar 2008
    inner west syd now!
    Quote Originally Posted by Shifty View Post
    you're wrong, if it's flow metered and you're losing 10psi then it will be running rich as a motherfucker
    i know, i have already said that, aybe he just isnt picking up on t overfuelling, he is a noob dont forget
    Aug 2009
    no need for that.. I'm only 17 how much do you expect me to know
    Gearwhore. Backyard Mechanic
    Oct 2008
    Wastegate IMO.
    The above opinion is just that - my opinion. It is not shared by any business that I am currently or have previously been involved with, nor any of their employee's.
    My wife loves a Grease Monkey pauljones1976's Avatar
    Jun 2007
    Second the wastegate. It's definitely worth checking the actuator. (I'm assuming you have an internal wastegate here)
    The actuator has a diaphram inside. It is held in place with a spring and connected to the actuator rod which runs along to the wastegate flap on the exhaust side of the turbo. The diaphram is pushed toward the rear of the actuator when air pressure is applied to it. That air pressure comes from a feed from the compressed air side of the turbo. (it's easiest to think of it as a tiny little feed of 'boost'.)
    The spring in the actuator also holds the wastegate flap closed. If it werent' for the tension in the spring, as soon as exhaust gas pushed on the flap it would open, allowing gas to escape rather than to spin the turbo.
    The rod will only start moving when the air pressure from the compressor feed exceeds to force required to overcome the spring tension (ie: 7/8psi stock) so under normal circumstances you recieve 7-8psi.
    When you bleed air with a manual boost controller you're just allowing some of the 'boost' in the feed line to the actuator escape, letting less air pressure (boost) into the actuator diaphram. In effect it is tricking the actuator into thinking the boost is lower.
    The wastegate flap is constantly under pressure to open from exhaust gas pushing on it as it rushes by. The more pressure (volume of air) the turbo is injecting into the engine, the more exhaust (volume) is being generated which is putting more pressure on the wastegate flap.
    If the actuator spring doesn't have enough tension to hold the wastegate closed as the pressure on the flap increases, the flap will open and the tubo will stop increasing boost.
    So once pressure on the wastegate flap exceeds the spring tension in the actuator, it doesn't matter if you don't have enough 'boost' being fed into the actuator, the diaphram is not moving from the air pressure pushing it toward the rear of the actuator anymore, it's being moved because it's being pulled by the wastegate flap pulling on the rod.
    An easy way to check is to remove the compressor ('boost') feed to the actuator (just disconnect it from your boost controller - it doesn't need to be plugged up or anything to test this. You want the side that has the arrow pointing to it if you have one of those turbosmart ones. Otherwise it's the side that runs into the nipple on the actuator.
    If you're really not sure, just pull the boost controller out of the line and leave them both open.
    What you've effectively done is stop air being forced into the actuator, pushing the diaphram, and opening the wastegate.
    *** THERE IS NOW NO CONTROL OVER YOUR BOOST LEVEL - BE CAREFUL ***
    Now CAREFULLY get the car on boost and see if it goes over 10psi. If it does, then you have some sort of an air leak somewhere. If it doesn't build any more boost than 8-10psi then the actuator isn't strong enough to hold your wastegate closed and you'll never reach a higher boost with just the boost controller. You will need to replace your actuator (or modify it with more spring tension).
    -Paul.
    "If you keep fixing it for long enough, eventually it WILL break."
    - RA28 3TGTE - I sold it. Bad idea. www.glisten.net.au/celica/index.htm
    - RA23 3TGTE - 168rwkw 12.9sec Toffee Apple [URL="http://www.toymods.org.au/forums/threads/26625-RA23-3TGTE-168rwkw-12-9sec-Toffee-Apple?p=561925#post561925[/URL]
    Aug 2009
    Paul,
    Thanks for explaining the function of the wastegate actuator and sharing how to check what the problem is, I will definitely do this test today or tomorrow and post up my results.
    Thanks for explaining it in so much detail, I understand how the wastegate actuator works now
    Aug 2009
    I done the above test today and i hit 14 PSI before backing off.. seems I must have an air leak.
    Im going to get new clamps and a new 90 degree bend hose from my 'cooler as I think this is the problem hose.
    If this fails then i will try adjusting my BOV.
    Thanks to the people who had constructive feedback and ideas/help
  8. #38
    codez, follow this video http://www.youtube.com/watch?gl=AU&h...&v=atretf9u-Mc
    will enable you to find your boost leak.
    RA23 - Twincharged
    JZZ20 - Daily
  9. #39
    Aug 2009
    Thats a really good vid, thanks for the link.
    + Rep.
    Project:RA65 with an engineered 1ggte conversion.
    Daily:MA61 - 5me stock auto shitheap.
  10. #40
    Aug 2009
    Kedderz, thanks for the link mate it will be really helpful!
    Also thanks for the previous help and tips
  1. Implementing a form of closed loop boost control on Wolf v500 ECUs
    By OnAll-FOUR in forum Tech and Conversions
    Last Post: 08-10-2009, 06:33 PM
  2. 2jzgte - strange surging boost when cold
    By PlacentaJuan in forum Tech and Conversions
    Last Post: 15-04-2008, 10:56 AM
  3. Hybrid Boost Controller Installation
    By doobs in forum Tech and Conversions
    Last Post: 31-03-2007, 01:19 PM
  4. Trying to wire up solenoid valve to boost controller?
    By trd-st162 in forum Tech and Conversions
    Last Post: 21-11-2006, 08:35 PM
