Results 16 to 27 of 27
Thread: Battery arcd out - car wont start
    Aug 2009
    Default Re: Battery arcd out - car wont start
    sounds like it could of surged thru the igniter... checky checky my friend ive heard of ignitors shutting down injectors when there is no spark so the motor doesnt flood
    Aug 2009
    btw.. ignitor is usually under the coil.. which looks like abit of a heat sink... looks in that pic that its on the passenger side strut tower near your air flow meter
    Jan 2010
    Quote Originally Posted by pandaah View Post
    Yeah that makes sense, i was thinking to myself before 'ive cranked this engine abit so wouldnt it be filling with fuel, but theres no fuel smell?'. Hence the injectors are off because of no spark like old matey said before.
    Yep i found the sucker, Good old google images!. Maybe it is this little bastard, i hope so, i makes abit of sense..
    Any idea on how to test it if possible?.. There should there be power going to it aswell right?
    WTB 15'' Rims
    20v AE82 Track Car - WP 1.17.7
    20v AE82 Street Car: Going Really Well
    Falcon ute, Slippin auto & a worn steerin rack
    Aug 2009
    would be easier just to try another one.. or id imagine there would be a resistance test in the workshop manual to test if the unit and internal circuits are working.... (which i dont have sorry lol)
    must of just somehow cop'd a surge of power and fried it.. or its just a conicedence... eh who knows, try see if a second hand unit fixes the problem first..
    also, while your working on your car see if you can cross the TE1 and E1 pins in the diagnostic port plug in the engine bay and see what (if any) the engine light flashes
    Quote Originally Posted by munkey View Post
    Ive played with the fuel pump and can see how it works so thats no problem now cheers. thanks for the diagram mate.
    Ahh ok i was thinking the computer had something to do with controlling the spark..
    So in theory its possible to crank the engine and it will produce spark without even having the computer connected ?
    Unfortunatly this is my first toyota so i have no yet accumulated any parts.. i have enough spares to build another falcon on the other hand
    So where is the ignitor located?. Is that the most likely thing to flog out given the circumstances?
    The computer does control the spark, but it waits for confirmation from the ignitor that ignition occurs for it to continue pulsing the injectors.
    Some ignition checks in this pdf dood.
    http://www.autoshop101.com/forms/h23.pdf
    Tallahassee, FL USofA
    3- The fuel pump does not prime when ignition is turned to on
    Did it before, most don't?
    Are there any fuse/circuit breaker under a kick panel that's on then opposite side from the one with the little fuse box access door?
    Jan 2010
    There is one 20amp fuse in the L/H kick
    WTB 15'' Rims
    Jan 2010
    I just changed the igniter and it still doesnt run. Still No Spark.
    Is there ment to be power to the dizzy?
    WTB 15'' Rims
    nah there is no power to dizzy. It has four wires which go to the computer, ones an earth and the other three are signal wires. (These are generated in the dizzy itself).
    If your certain the replacement ignitor is serviceable and the coil is powered then i would assume the computer is not sending the signals to the ignitor to tell it to spark. Which suggests to me the dizzy may not be working, you can check the resistance between the terminals and make sure none are open or short circuit. Further test would require a scope or spare.
    PS. How have you tested fuses and fusible links etc? (I know its been asked several times but I haven't seen a response. I only ask because I have had fuses which look fine but didn't conduct).
    Gearwhore. Backyard Mechanic
    Oct 2008
    Only test fuses with a test light or multimeter. Eye-test fails unless they've had a lot of juice go through them.
    The above opinion is just that - my opinion. It is not shared by any business that I am currently or have previously been involved with, nor any of their employee's.
    Aug 2009
    as far as im aware.. the ignitor accepts an input from the ecu, which is told what to do by either a cam or crank angle sensor or both..... so if your ignitor isnt powering up.. id say checking power and earths to the ecu.. or trying another one....
    sorry to say.. i hope im wrong tho!
    Jan 2010
    Exclamation diagnosed
    Thanks for your help guys, Ive learnt a few things i didnt know a couple of weeks ago after playing around with my car in the shed.
    It turns out it was a snapped timing belt
    WTB 15'' Rims
  1. 3s-fe cold start problem
    By neon in forum Tech and Conversions
    Last Post: 15-11-2007, 10:53 AM
  2. Stock/Standard JZS147 Aristo Battery CCA Rating?
    By Esteban in forum Tech and Conversions
    Last Post: 09-10-2007, 06:40 AM
  3. car wont start
    By Mr DOHC in forum Tech and Conversions
    Last Post: 22-09-2007, 02:52 PM
  4. 4age wont start, distributor?
    By carsanactra in forum Tech and Conversions
    Last Post: 25-01-2007, 05:29 PM
