Results 1 to 8 of 8
Thread: car wont start
    Default car wont start
    ok, i have a RD colt, lately it has been weird
    it wouldnt start in the morning but u can clutch it no worries, as if the battery is dead, but my wife had no worries at lunch time and after work, but every so often it woundt start after work, but she just clutched it again.
    now its getting worse, it wont even try to crank over, even whith 12.6v in the new battery and a set of jumpers off the cressy which is showing 14.4v
    it seems like i have a dead starter, does this seem like the general consensus
    The boobs are back
    Default Re: car wont start
    sounds like the starter or the starter relay,
    next time, take a broom out to the car with you, if it doesnt want to turn over, give the starter motor and solenoid a good couple of wacks with the broom handle,
    did the job for an old shitter that mum used to have years ago
    blake
    i did whack it a bit, but its under the inlet manifold,
    if i rip out the starter is there a way i can "jump" it to see if it works
    The boobs are back
    yep, just attach the battery POSITIVE to the BIG terminal on the solenoid, and the negative to the body,
    if it sounds unhealthy/turns (rough noise's) slowly or does nothing, its rooted
    its should spin up quickly, and sound smooth, if its good, m,aybe grab another from the wreckers $20 id assume
    could also be that the starter motor solenoid is not getting 12V when you put the key to STA, locate the wire from teh switch in the the engine bay and use it to trigger a relay that's fed from a decent 12V which then powers the solenoid.
    other way of fixing said mitsu shibox requires tin of petrol and some matches.
    dont wanna do that, it so economical, and fun to drive
    but when it was being a bitch to start it actually was cranking, just very slowly
    The boobs are back
    Quote Originally Posted by Mr DOHC
    either solenoid isn't getting a decent signal (see relay thing above) or the starter's cactus - i'd try the wiring solution first before removing starter.
    fuxed, starter caput, got one from a wrecker
    thanks all +rep
    The boobs are back
  1. 4age wont start, distributor?
    By carsanactra in forum Tech and Conversions
    Last Post: 25-01-2007, 06:29 PM
  2. 4agze hard to start and then stalls
    By wiso in forum Tech and Conversions
    Last Post: 08-12-2006, 12:31 AM
  3. DIY alram install (auto start), for n00bs
    By PlacentaJuan in forum Tech and Conversions
    Last Post: 29-06-2006, 04:19 PM
  4. 3SGTE Hard to start
    By SilverGhost in forum Tech and Conversions
    Last Post: 27-01-2006, 12:16 PM
