Page 9 of 12 FirstFirst ... 7891011 ... LastLast
Results 121 to 135 of 180
Thread: The Magic 300 1jz
  1. #121
    Default Re: The Magic 300 1jz
    For cams. A smaller exhaust cam to the inlet will aid in spool, but will hinder up top.
    300RWKW on stockies.
    I'd say it's 100% acheivable, how long the stockies last, is a totally different question.
    I'd be looking to get the inlet charge as cold as possible. To the point of cooling the turbos themselves down with something damn cold. (C2O setup on the turbos? )
    Although, that'd only be drag useful.
    Maybe look at doing a full W-2-A setup along the WHOLE inlet piping, and setup something like your air con to be cooling the water (Instead of inside)
    To pick up other power as well, remove things like P/S pump, hydro fan (if you have one) and anything else not needed.
    My Dead Supra...
    Quote Originally Posted by ReQuieM in the A70 Thread
    There is some serious talent in this thread for linking anything to fuckin gay sex. Its extraordinary.
  2. #122
    TRB01J Backyard Mechanic jak's Avatar
    Jun 2007
    i dont think its nesacery as long as you have a nice free flowing exhaust.
    stock dumps kill ct12a's. thats the problem with the stock setup and over boosting.
    Jak
    '77 RA28 Celica - Repairing Rust...
    '84 AE71 Daily Driver/Race Car
    '91 MX83 - Fastest Standard Turbo 1JZ Powered Vehicle In The World -
    10.74 @124 Mph
    http://www.youtube.com/watch?v=H2ido6yirZ8
  3. #123
    Quote Originally Posted by jak
    Jak
    Heat, RPM, and Time kill turbos.
    Generally you can have one or two, and not kill them, build up all 3, and you're gone.
    Stock dumps would be restrictive, trapping in heat, for long periods of time.
    To make 18PSi is high RPM (Probably higher then with a free flowing exhaust)
    And as such, they die.
    Try spinning to 25PSi, you're at extremely high RPM, with alot of heat (out of efficiency) and depending how long you stay on it, depends on time.
    Keeping shit cool is an easy way to succes.
    Plus, 25PSi at 150degrees, is a fair bit less oxygen at 25PSi at 30degrees with the same volume.
    My Dead Supra...
  4. #124
    Jun 2007
    yea, the stock dumps trap heat like a bitch.
    i should know, i run 25psi.
    and we dont run any unusual cooling devices. we daily drive them on 19psi and have been doing so for 1.5 years. u wont get them above 22psi without nitrous. we can see 22 without nos and all is fine.
    Jak
    10.74 @124 Mph
  5. #125
    Jak
    Define "Won't get them above"
    As in, they won't flow it. At full tilt, wastegate closed, they won't boost over 22PSi
    Or they're just not making any more power?
    If just not making more power, start by cooling the turbo itself down...
    My Dead Supra...
  6. #126
    Jun 2007
    no, it wont physically create more boost. urbos are maxxed out.
    i know what your sayin about keepin em cool, if we get them to make more boost with more nos, the nos is the cooling effect, but if u bore and stroke it (unlikely but anyway) your going to have to keep them cool to take advantage of the extra boost, otherwise it will just be heat.
    Jak
    10.74 @124 Mph
  7. #127
    Hrm...
    See, I've never heard of the CT12As limiting themselves.
    I know the turbos on the 1G-GTE will do it...
    Does it still limit boost with new manifolds as well as dump?
    My Dead Supra...
  8. #128
    Jun 2007
    dont know about manifolds. we run the complete stock setup.
    all turbos have a limit. and the ct12a's dont go above 22-23psi without nos.
    Jak
    10.74 @124 Mph
  9. #129
    UpdaTes?
    JZA70|R / 12.45 @ 111 mph.
  10. #130
    AU
    300rwkw on stockies .... lmao.
    It's like reading a Martin Donnon article.
  11. #131
    he did 250rwkw which is about 5kw more than me
  12. #132
    Xistant
    Guest
    258rwkw's @ 18psi IIRC.
  13. #133
    Xistant
    Guest
    that was with the hks EBC (faulty valve) he should really get it tuned / dynoed again with the PFC BC in after his car comes back from paint
  14. #134
    make sure he doesnt slack off. i want to see some results!!!
  15. #135
    Xistant
    Guest
    i think hes gonna ditch the stockies for some disco pots, but thats an idea in the head i guess.
  1. 1jz vs 2jz heads
  2. 1JZ into EA Falcon
    By bezza05 in forum Tech and Conversions
    Last Post: 27-01-2006, 10:18 PM
  3. Upgrading 1JZ alternator
    By beasht in forum Tech and Conversions
    Last Post: 19-01-2006, 08:28 PM
