Results 16 to 22 of 22
Thread: ma61 diff in a ta22?
    Default Re: ma61 diff in a ta22?
    Quote Originally Posted by river
    LOL!!!!
    Not true... the 18RG-powered RA25GT is sooooo fast that when I went to Dubbo on the weekend I arrived before I left, due to the time dilation - such was the speed!
    Oh, and another thing, RA25s have rear drum brakes. Not cos it's slow, but 'cos it's a man's car!
    seeyuzz
    river
    so having front and rear drums makes you a god? or just two men?
    Off the diff subject for a post or two.
    How does one mate the W55/58 to the 4A motors?
    Which bell housing is used?
    Regards
    Rodger
    New Zealand
    Custom as no factory bellhousing matches up, Nite Parts from NZ is supposed to be very good quality.
    Callum
    Quote Originally Posted by weapon x
    i'm not even sure if i would need lsd or irs
    does anyone know for what reason i should have them given the setup i mentioned, what are the advantages of them and disadvantages?
    You don't need IRS, and given the difficulty/expense of getting IRS in a TA22 I'd suggest you don't want it either. As mentioned earlier the MA61 semi trailing arm IRS isn't especially good anyway, so if you went down this path you'd want to use something better such as S13/S14 Silvia IRS (double wishbone).
    LSD isn't necessarily something you need but when you've got a decent amount of power you definitely want it. What's the point of having power if you just light up one wheel everywhere? Two wheel traction is what you need to get the power to the ground, and that's where an LSD comes in. You can either get a T series LSD centre to suit your existing diff, or upgrade the entire diff to a stronger one (eg F series) and put an LSD centre in that.
    Thanks Callum,
    I thought I might have missed something all these years.
    Regards
    Rodger
    Junior Member Domestic Engineer weapon x's Avatar
    cheers for the info guys...
    very good to know all these things, before one carries the pain of putting money into something one shouldn't.
    as for the remarks to the 4a being a "small" motor... my mates celica... 11 sec 1/4 mile.... not bad for a "pueny" motor hey...
    another question... is it worth putting disks on the back? if the front do most of the work, how much does the back really do?
    The rear brakes don't do much, so it may or may not be worth upgrading them depending on how you use the car. If the car will see any circuit work some decent rear discs are a must, but for street and occasional drag strip use it's not really necessary.
  1. changing the gear ratio's in hilux diff.
  2. Diff Problems in Ta22
    By 13BTTA22 in forum Tech and Conversions
    Last Post: 25-02-2006, 08:51 AM
  3. What is the best oil to use in a stock MA61 diff?
    Last Post: 12-01-2006, 09:12 PM
