Results 1 to 13 of 13
Thread: piston to bore clearance..
    ditty man Grease Monkey
    wa
    Default piston to bore clearance..
    whats hte piston to bore clearance for my gze.. its got oversized 20 thou pistons in it. i think te dude said at te moment there is a 1 thou of clearance or somethn likethat :S
    Default Re: piston to bore clearance..
    Depends 'where' the 1 thou clearance is as well...
    If there's one thing I know, it's never to mess with mother nature, mother in-laws and mother freaking Ukrainians
    wa
    would it be the same as a 16v ge?
    I can't say for sure - most piston to bore clearances are between 1 and 3 thou (depending on the type of piston, cast, forged, alloys etc). Usually there are manufacturer recommended specs that your machine shop *will* know (or if they don't, they should find out before they do the machining). Often aftermarket pistons come with recommended clearances too (and where to measure them from etc).
    You need to stop panicking about your rebuild
    vic
    dont set forgies at 1 thou , you will see why when it gets hot.
    1 thou is good for cast pistons in smaller motors , you will have to be gental running it in tho , most machinests bore to 2 and a bit to cater for thrash and go people.
    wa
    so dont go wit 1 thou.. so you think go with 2 thou then.
    also where can I find oil clearences for the pins and bottom end of hte motor, torque settings for oil pump.. big end caps... timing details and things.. I do have a manual for a 4age 16v so I wasnt sure if it was the same.
    my work uses 1.5 on att cast pistons
    The boobs are back
    vic
    1.5 thou is a good , still have to be a little carefull when running in, but u end up with nice quiet pistons , less rattle = less wear.
    if the 4ag you plan to build doesnt have forged pistons then id go 1.5 thou . up to your builder tho as some will say thats to tight.
    wa
    they are the brand new ones that toyota suplied for the ae101 gze (ceramic coated) and i think they are forged as well correct?... so what should I be doing for forged.
    Washington, USA
    for forged i'd go atleast .0025-.003" clearance. especially if you going to be turning up the wick later on.. (now if they were some aftermarket pistons then you would go with what they say to do.)
    my turbo engine has .0055-.006" clearance. she only rattles on very cool mornings but otherwise I dont notice it. after shes warmed up it goes away..
    72 RA21, 77 RA29, 78 RA40, 79 RA42, 83 RA65c, 85 RN60
    81 RA42 race car, 04 F150 supercab tow rig.
    just go with what the piston manufacturer says to
    The boobs are back
    S.A
    your specs will be the same as a 4age so use the work shop manual m8
    As for the piston pin specs i had trouble finding some when i built mine. I just made sure that the pin moved through piston and rod easily (not too tight) i used a bit of 1200 on my finger to clean up the piston (where pin goes through)
    Washington, USA
    go with a 4agze specs they may not be the same a n/a 4age with cast pistons.. especially if your going to run more then stock boost, then the factory specs are out the window also..
    By The Witzl in forum FAQ
  2. T, 2T, 2T-B, 2T-C & 2T-G Specifications & Diagrams
    Last Post: 29-02-2016, 11:30 AM
  3. Breaking a GZE piston or rod
    Last Post: 16-05-2006, 09:56 AM
