Page 1 of 3 123 LastLast
Results 1 to 15 of 38
Thread: Open-ended budget 4AGE build - with some restrictions
    Gearwhore. Backyard Mechanic
    Oct 2008
    Default Open-ended budget 4AGE build - with some restrictions
    Say you have a basically open-ended (within reason, ie. not $50k) budget to build a supercharged 4AGE for a track engine. There are a few restrictions:
    *must be a 4AGE bottom end (ie. no 7A cranks)
    *must be a bigport head
    *must be supercharged
    *must be built for a 4000-7000rpm powerband
    *must be tuned conservatively for reliability, but at least 200rwkw
    *must last at least 50k kms before needing any sort of rebuild
    *must run on E85
    *will be mounted EW.
    How would you go about it? I have some idea's as to how I would like to do it, but more interested in what other people would do. Yes I am well aware I could just get a GZE and throw a turbo on it, but have zero interest in that whatsoever.
    Oct 2009
    Default Re: Open-ended budget 4AGE build - with some restrictions
    if you have a (reasonably) open ended budget, why not do something crazy?
    Oct 2008
    Quote Originally Posted by destroyer View Post
    Like what? I have to stick sort of within those recommendations for my class. Yes I could do a 3SGTE/1UZFE/2GRFE conversion for roughly the same price but not interested.
    Jul 2007
    those restrictions really undermine the open-endedness of your engine build lol. for one thing you wont be making 200KW at the wheels on an sc12 with a "conservative, reliable tune" thats for sure!!!
    Oct 2008
    How? Did I ever say it had to be a SC12? 200rwkw is only 20 something psi of boost for a stock GZE, stupidly easy for any non-Roots blower.
    not that easy, 20psi+ is still challenging for screw blowers, in terms of leakage, power consumption and heat generated...
    twin charge?
    does the class have an intake restrictor?
    Oct 2008
    twin charge?
    I fail to see how 20psi is difficult, if I'm not mistaken the Mazda twinscrew blower is good for 21psi on a 2.3L (I think) engine. Considering my engine is considerably smaller, with a ~1.4L blower it should be easily doable. Not interested in twin-charging, have looked at it and lots of fucking around for not much gain (it's not really that efficient, especially looking at some of the newer twinscrew blowers).
    No intake restrictor, was thinking for shits and giggles I'd run a custom plenum and quad throttlebodies (possibly from a GTIR or similar).
    For those interested in my sort of budget, I can source basically any car part you could possibly imagine at trade price or lower, plus I have people who will do all the engine work for basically a couple of cartons (all machining, balancing, head work, putting engine together, ceramic coating, etc). I have at least one proper sponsor who has already given me the definite nod for when the car is more complete, plus another one who is still deciding to what extent they want to sponsor the car.
    Jul 2007
    must it be supercharged? i cant see why you wouldnt just go turdbro unless its a class restriction of some sort.... if you really can get all the engine parts/work done cheap then i would be looking at running a lot more boost and making a lot more power than that. take a look at what bazda has going in his car over in NZ for a serious business yet reliable track setup.
    also, 50,000kms sounds like a lot for a track engine which will basically never see anything less than 4000rpm whenever its running. then again im not all that wised up on these things but yeah... doesnt sound right to me.
    Jul 2009
    If I was going to do this kind of thing, this is roughly what I would hash out.
    4AGE 20V Blacktop - Rebuild the bottom end to have forged rods and pistons. Possibly stick with the 10.5:1 compression depending on how well E85 can keep it from knocking with 20psi. Stick with the ITB's and add a BOV.
    Lysholm 1600 A-AX Twinscrew - Good for well over your power needs, relatively cheap too as shown in Gun's SC12 thread.
    Water2Air Intercooler - Big assed unit to keep intake temps down and allowing a high flow, shortest path possible intake.
    Probably some other things I'd look at, but I'm just spitballin
    oregon
    superchargers = Rotrex(small, compact, works VERY well)
    You said no 7A cranks.... what about using a 7A block with a custom fully counterweighted 85mm stroke crank??? The added 200 cc of stroke will go a looong way
    Assuming you can't do that.... for reliability I'd go with a mix and match. Find a smallport block (squirters) a 42mm rod journal crank Also last gen TVIS rods. Finally AE101 4AGZE slugs. Oversize valves and a complete porting job (not quite to F/A sizes... but close)
    Cams... maybe custom - 256(definately no more than 264) with as much lift as the cam maker can provide
    Management - something good
    Last edited by oldeskewltoy; 04-03-2010 at 11:57 AM. Reason: corrected info... crankshafts
    Jul 2007
    last generation tvis crank strongest????? dude the cranks are identical across all 4A generations (bar the 3-rib block)
    Sep 2008
    ^ this.
    Now there is gonna be more jargon across the Internet about 4a engines
    The GOD HAND AW11 - sold
    oregon
    apologies... you are in deed correct.... too much coffee this am
    I feel the OP question is a bit difficult to answer.
    You want 200kws but no turbo and no twinscrew charges?
    Does it have to be a 4age or a 1.6L?
    Also reving the motor at 4000 - 7000rpm for 50,000kms could be a problem for the motor.
    Jan 2007
    queensland
    i don't think it would be a problem.. definitly nothing toyota issue in the bottom end aside from the crank, oil pump..
    everything else i would go aftermarket, the stock stuff MIGHT get away with it.. as it is only 7k.. but i wouldn't risk it..
    again stock over bucket shims may well and truly last.. but i wouldn't risk it.. i would use underbucket shims..
    if you want a bit of a run down, from a guy who has built almost everything from hi powered daily SR/CA/3S/4E, to 800hp RB's... and many many many NA SBC, clevo etc etc making over 700hp on pump fuel in streeters..
    Kohen - KJ Motor Machining (same unit as Extreme Custom Engineering)
    0403 748 607
    Unit 2 - 142 Beatty Rd Archerfeild..
    he will be able to give you a quote and some idea's for the engine itself, and porting/head work/cams etc etc...
    if you go and see him in person you can talk to Craig about doing the pipework/cooler, custom tuned length extractors, cage, ally radiator etc etc etc all of which you might be interested in for this project of yours...
  1. 4AGE Build
    By the_random_hero in forum Tech and Conversions
    Last Post: 04-04-2009, 08:44 AM
  2. 4AGE 100kw into AE92 (where 4AFC used to live)
    By Grega in forum Engine & Driveline Conversions
    Last Post: 24-07-2008, 05:53 PM
  3. TC1600's budget 4AGE rebuild (warning- pics)
    By TC1600 in forum Tech and Conversions
    Last Post: 27-09-2007, 10:12 PM
  4. AE86 : 4AC -> 4AGE conversion on a budget
    By li21 in forum Tech and Conversions
    Last Post: 09-06-2007, 01:12 AM
  5. 4age build
    By mulkers in forum Tech and Conversions
    Last Post: 25-05-2007, 09:28 PM
