well if that is the blue S2000 he was talking about... it may make 350hp on the dyno... but it's not that impressive on the highwaynot against other cars with less or the same power.. still quick though..
ahh rotrex... lag of a turbo with mechanical loss of an SC... best of both worlds...
i suppose the linearly increasing boost makes it easier to driveor good for dyno queen?
Yes to both accounts.
Power response is very linear, he's currently in the middle of getting a larger blower, stronger diff and then upping the boost somewhat.
Fresh from customs today
He is yet to give it a real stab on the roads or on the strip, he's too much of a bitch worrying about his diff (apparently they are incredibly weak when you throw boost into the mix).
The above opinion is just that - my opinion. It is not shared by any business that I am currently or have previously been involved with, nor any of their employee's.
it's linear in that the boost is linear with rpm..
ie low at low rpm, then high at high rpm
so you get a steeper linear power curve than if properly SC'd, but missing all the midrange
good for dyno queens or drag cars that only need a small high rpm range..
ie,
top two (flat) curves are SC's (eaton starts ok and goes down at higher rpm, KB starts lower and picks up with rpm), the middle one is typical turbo..
the lower curve... is centrifugal charger... looks pretty shit really....
1 thing to note about that test is the displacement of the Eaton versus the Twin Screw SC.
An M112 displaces 1.836 litres/rev. The Twin screw is a 2.2litre/rev.
The Eaton was turning at over 19000rpm.
"Don't worry what people think, they don't do it very often."Originally Posted by oldcorollas
The Rotrex has what they call traction drive technology -more advanced, but similar to a plantery gear drive system... so it a fair amount of boost earlier and holds it better then a conventional centrifugal S/C
http://www.rotrex.com/Home/Technolog...t_Concept.aspx
I would not do this and I don't think that you'll find any valid reference except for going to 200 or 240 degrees, not 360. While it lets the mains do more rod oiling, their reduced load capacity doesn't help. Also, grooved rods are are going to be very difficult to find!
