Page 3 of 3 FirstFirst 123
Results 31 to 36 of 36
Thread: 1GGTE Oil Pressure
    Sep 2011
    Christchurch
    Default Re: 1GGTE Oil Pressure
    All you need to do to shim the oil pump is remove it from the front of the motor and undo the big bolt (carefully since it has a spring behind it) and place a washer ~1.5mm thick in the bolt for the spring to sit against so it is under more tension which raises the pressure at WOT. And I do believe it is a worthwhile thing to do, since these have a habit of oil starvation to 1 and 6 big ends.
    i think i did one the other day
    88 gz20 soarer built 1ggte gt30/40 osgiken twin plate j160 gearbox.
    Junior Member Backyard Mechanic scottreichstein's Avatar
    Aug 2011
    +1 arthur thanks ill do it while i have the motor on the engine stand cheers
    RIP st141 died doing what it loved http://www.facebook.com/media/set/?s...type=3&theater
    1ggte hilux massive 143rwkw http://www.toymods.org.au/forums/sho...724&highlight=
    corolla sportivo daily LIFT
    open up the oil galleries while your there
    Built motors often make random noises like that when they are first started up.. Could it not just be attributed to that?
    Facebook | LinkedIn
    Could be, mine doesnt do it though, its built
  1. 1JZ Fuel Pressure Regulator Limits
    By beasht in forum Tech and Conversions
    Last Post: 19-04-2008, 05:17 PM
  2. 18R-C Oil Pressure Switch
    By Raforty in forum Tech and Conversions
    Last Post: 15-01-2008, 01:10 PM
  3. a few pressure regulator and injector rail q's.
    Last Post: 20-11-2007, 06:34 PM
  4. 3sgte oil pressure lights purpose
    By Howieau in forum Tech and Conversions
    Last Post: 13-11-2007, 11:48 AM
  5. Replies: 3
    Last Post: 29-05-2007, 04:18 PM
