Results 1 to 10 of 10
Thread: st185 tacho with adaptronic
    Mar 2008
    queensland
    Default st185 tacho with adaptronic
    Hi guys, i have just recently upgraded from the dizzy to a bank of ls1 coil packs and have removed the standard igniter/coil and the tacho no longer works, i have tried wiring it to the adaptronic on the tacho output however it doesnt work, i believe the adaptronic sends a +ve signal where the tacho requires a -ve signal. does anyone have any experience in toyota tachos on aftermarket ecus?
    Tim
    Default Re: st185 tacho with adaptronic
    you could try this:
    http://www.toymods.net/forums/showthread.php?t=3710
    Slight simpler
    Can ditch the diode on the input.
    Wilbo's JZA80
    Wilbo's JZZ12
    http://www.adaptronic.com.au/forum/i...sg6103#msg6103
    even simpler just use the relay coil itself.
    (I have done this on a car and it works)
    Quote Originally Posted by 7M-GTE MX73 View Post
    Makes sense, the adpatronic has the NPN in it
    Wilbo's JZA80
    Wilbo's JZZ12
    Mar 2008
    queensland
    awesome thanks guys ill let you know how i go.
    Tim
    Mar 2008
    queensland
    Hey guys, got the tacho working however it isnt accurate, it was also like this on the stock distributor setup, 7000 is actually 5000 on the tacho, does anyone know how to correct this or do i need a new tacho?
    I'd try a new tacho.
    if it was like that on the stock system, your tacho is definitely dodgy.
    get a new one.
    Mar 2008
    queensland
    Replaced the tacho unit as it smells a bit burnt out, guessing a capacitor is gone, but yeah its all good again.
    Thanks for ya help guys.
    appreciate it.
  1. 4cyl tacho with 6cl engine can it work?
    By duggy in forum Tech and Conversions
    Last Post: 15-10-2009, 04:01 PM
  2. Tacho tech
    By Hen in forum Tech and Conversions
    Last Post: 04-08-2009, 04:10 PM
  3. 4 Cyl ---> 6 Cyl Tacho Swap.
    Last Post: 30-01-2007, 09:36 AM
  4. RA40 tacho & aftermarket ECUs - anyone had trouble?
    Last Post: 29-11-2006, 03:59 PM
