Results 1 to 4 of 4
Thread: 4cyl tacho with 6cl engine can it work?
    Junior Member 1st year Apprentice duggy's Avatar
    Jul 2008
    Default 4cyl tacho with 6cl engine can it work?
    hey guys ive got a 180sx with a 1jz i want to get the standard tacho to work i was reading a few threads about tacho boosters but im not sure if this will suit my needs.
    so i have just a few questions.
    will the nissan tacho read the toyota signal at all?
    will a tacho booster make my gauge read right?
    if a tacho booster is not what i need is there anything that will fix the problem?
    Default Re: 4cyl tacho with 6cl engine can it work?
    I thought you'd mentioned that you had the tacho working it was just reading wrong?
    If you have the tacho reading (albeit wrong) then you very well might not need a booster...
    Not being familiar with 180SX's I'm not sure if it is possible to take the dash apart and 'calibrate' it to work with the 6 cyl tacho output from the 1JZ....
    If it isn't possible to calibrate the dash then one solution might be to use something like a Jaycar speedo corrector to correct the 1JZ tacho signal... and you might need a tacho booster after the speedo corrector depending on what signal your dash works off...
    e.g.
    http://www.jaycar.com.au/productView...o&form=KEYWORD
    Wilbo's JZA80
    Wilbo's JZZ12
    Jul 2008
    na my mates rb25 powered silvia is working but reading wrong i though mine would be the same but i spoke to some one who said the signal will probably be different and might not work at all.
    A solution on some toyotas is to get the guts out of the tacho from a 6 cyl instrument cluster (eg Camry) & fit it behind the 4 cyl face.
    The sweep of the needle needs to be the same though.
    May be a thought to try?
  1. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 07:27 PM
  2. MA70 --> JZA70 Conversion
