Results 1 to 3 of 3
Thread: Setting ignition timing
    Roflcopter Pilot Backyard Mechanic thu187's Avatar
    Unhappy Setting ignition timing
    Hey guys,
    Took the dizzy out and silly me never having done it before made markings on the flange. I was playing with the rotor spinning it around when I realised oh shit, this was what I was supposed to mark!
    So now the ignition timing will be out. I'm a mega nub but I can follow instructions and want to learn as much as I can so I want to do this myself.
    Can someone tell me if this is the correct method:
    1. Make sure cylinder 1 is at TDC (compression stroke).
    This is done by aligning the camshaft pulley groove to 0. Then checking to see the cavity of the camshaft after removing the oil filler cap.
    2. Once cylinder 1 is at TDC, turn the rotor to point at the #1 spark plug wire on the distributor cap.
    Is it as simple as that? Also when it points at the spark plug post on the distributor cap does it need to be pointed right in the centre of it and a few mm makes a difference or is it okay if i get it as accurately as I can, lining it up with a tape measure.
    Thu
    Edit: Engine is a 4A-GE in an AE86.
    [T]echnology is the only [R]eplacement for [D]isplacement
    Default Re: Setting ignition timing
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    For some reason the 4age manual I have didn't have that!
    Thanks Joel! LEGEND
  1. The Tuning Talk Thread - Forced Induction EFI & JZ Tuning.
    By JZA70 R in forum Tech and Conversions
    Last Post: 26-05-2013, 07:13 PM
  2. Ignition Fundamentals..... what's in a spark???
    By RAd28 in forum Tech and Conversions
    Last Post: 14-06-2009, 06:29 PM
  3. 18R-C ignition timing
    By Ryan1980 in forum Tech and Conversions
    Last Post: 26-01-2009, 02:00 AM
  4. Replies: 0
    Last Post: 20-07-2006, 12:18 PM
  5. Setting the Timing on a '90 Landcruiser
    By Yumbo in forum Tech and Conversions
    Last Post: 21-02-2006, 08:33 PM
