It sounds like a voltage drop in your trigger wire has it got it's own starter relay in the fuse box?? If so check the voltage coming out of the relay is efficiant enough or even the wire coming out of the barrell to the starter relay has efficiant voltage(could be a dodgy ignition switch).
If ignition switch is ok run a seperate wire and again hook up a fresh relay and it'll be fine, unfortunately you need to run a relay just to give it full voltage theres no way around it sorry dude..
