Results 1 to 5 of 5
Thread: JZA70 1JZ engine wiring - what's this plug??
    Don't Trust Me I'm A Backyard Mechanic Jabtronic's Avatar
    Gold Coast, QLD
    Default JZA70 1JZ engine wiring - what's this plug??
    Just wondering what this plug is for? It's on my JZA70 1JZ engine wiring harness in my MX83 and isn't plugged into anything so I'm wondering what it is. I noticed on GZ20-Jake's 1JZ converted z20 soarer that his is plugged in and the other wires seem to go to his fusebox.
    Mechanic Grease Monkey jzx81mx83's Avatar
    W.A
    Default Re: JZA70 1JZ engine wiring - what's this plug??
    im pretty sure that is to do with the alternator ill have a look at mine when i get home and tell you what colours go where.
    __________________________________________________
    89 GX81 Grande with manual single turbo 1jz
    Gold Coast, QLD
    Ok thanks, btw the plug is bundled with the igniter loom.
    W.A
    fat white wire , green with black stripe and yellow with green stripe these three go to the plug with 3 wires on the back of the alternator on the 7m ill let you no tomorrow night of sat where they join up on the plug from the 7m alternator
    Junior Member Automotive Encyclopaedia Hengsta's Avatar
    IF some have been cut off and been wired to some where else then it be fine.
    You only need to use 6 wires coming out of that.
    -Sleeper 2J + R154 X83
    -GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
  1. Sams MA61 7MGTE Conversion Guide
    Last Post: 07-07-2015, 11:12 PM
  2. MA70 --> JZA70 Conversion
