Results 1 to 6 of 6
Thread: 1JZ & AFR gauge question.......
    Junior Member Backyard Mechanic cptsideways's Avatar
    Dorset
    Default 1JZ & AFR gauge question.......
    Who's got a 1JZ with an AFR gauge connected???
    I've just connected mine up to my newly 1JZ converted Soarer & its appears to work, but.... it does'nt switch back & forth like a normal lambda gauge would, it just sits in the middle & hardly fluctuates, is this normal?? It goes to rich under boost though which is good.
    If not I may have wired it up wrong
    Sliding his D1 Soarer around the UK
    Default Re: 1JZ & AFR gauge question.......
    is it running a standard computer? im fairly sure they only swing when the car is running closed loop, so if your running aftermarket management chances are you wont be running closed loop ever!
    Dorset
    Quote Originally Posted by cri_ag
    It standard at the moment, only just fitted it all up.
    the guage has it's own wideband sensor?
    maybe your car isent going into closed loop running then? any fault codes?
    what is the price of the afr
    if its a cheapshit one under 150 or 200 bucks they arent very accurate
  1. 1JZ JZZ30 ECU D1 & FC COR Pins question
    By cptsideways in forum Tech and Conversions
    Last Post: 06-02-2007, 11:16 PM
  2. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
  3. JZA70 R Fuel Gauge Question
    By boris in forum Tech and Conversions
    Last Post: 17-01-2006, 12:03 PM
