Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
Thread: Should i buy a Clutch aglinment tool?
    Junior Member Backyard Mechanic ndgcpr's Avatar
    Default Re: Should i buy a Clutch aglinment tool?
    If its not dead central, or within 1mm of central, you will not be able to bolt the box up if the pressure plate is tight.
    The other option is to loosely do up the PP, put the box on, then carefully remove the box so that you don't move the clutch, and then tighten the plate down.
    Thats what i was thinking in fitting the old box without the bellhousing, then you would have room to do the bolts up
    Noisy Diff and Gearbox Club of Pine Rivers
    and you thought your car was loud
    The Soarer brought to you by the letter TT
    Junior Member Grease Monkey craigy's Avatar
    I use a kinchrome allignment tool, it was about $15 and i've used it about 10 times and havent had to bring the gearbox down once!
    It allows you to align the clutch and PP off the car and bolt it on as one.
    4AGZE powered AE86
    SR5 dual cab Hilux
    265 powered VJ Valiant Charger
    Western Aus
    lining up my mates clutch, i left the clutch loose, put the gear box in, then took it back out, and tightened it back up...
    was kinda hard, as the gearbox didnt come out PERFECTLY straight, so it slipped a bit, bt we managed to muscle it in alot easier.
    this is after we took a look at Matty (Wildsupra)'s clutch aligning tool, and laughed.
    Eldar.O.
    N.S.W
    Have a chat to the guys at your local gearbox place, you might get lucky.
    I picked up a stuffed input shaft for free when i was swapping the clutch in a VL, the guy just pulled it out of the bin for me.
    Saved a good 15 mins of stuffing around aligning the clutch, it almost went in quicker than it came out.
    Good. Fast. Cheap.
    Pick 2.
    Brisbane
    Over the years I have changed out a good 20-30 gearboxes, in fact probably more, and never used a clutch aligning tool.
    I've stressed a lot unnecessarily too, if I'd just spent the money in the first place....
    New Zealand
    I got one made by the local clutch place for $10, they simply machined it up from nylon type rod with the clutch kit and spigot bearing for reference.
    Callum
    OGT-630 Grease Monkey rokusan's Avatar
    mine is a long extention from my 1/2" socketset with masking tape wrapped around it to suit the spline, fits toyotas,nissans and fords!
    SA63-3SGTE coupe driftpig
  1. Clutch LSD => Torsen LSD
    Last Post: 21-10-2006, 02:14 PM
  2. Grease on flywheel / rear clutch surface..wtf!
    Last Post: 27-03-2006, 12:14 PM
  3. W58 7M-GTE clutch choice
    By RyleyMA61 in forum Tech and Conversions
    Last Post: 03-02-2006, 07:57 PM
  4. SC14 electromagnetic clutch
    By mic* in forum Tech and Conversions
    Last Post: 17-12-2005, 09:01 PM
