Results 16 to 30 of 42
Thread: W58 into AE71 Panelvan
    New Zealand
    Default Re: W58 into AE71 Panelvan
    Yeah, my RA63 box is second from left in the above pic so same as MA61.
    Callum
    MA61 is FAR left
    GX81 is next
    Then MA70
    and finally SA63
    Quote Originally Posted by CrUZida View Post
    MA61 is FAR left
    GX81 is next
    Then MA70
    and finally SA63
    Actually, GX81 is the far right with is the correct shifter to use in X8 manual conversion with a 6 cylinder engine using factory mounts (MX83 - 7M-GE, GX81 - 1G-GTE, JZX81 if you wish - 1JZ-GTE).
    The other shifter position may be available on shorter engines (4 cylinder or desiel) but i seriously doubt that because if the 6 requires the rear most shifter and its also the longest engine then it means the others are either further back in the engine bay of have a very long bellhousing and i dont think the W5x came with different lenght input shafts like the R154 did.That and the GX81 will always have a 1G engine.
    The R154 didn't come with different length shafts either, it was the R151 that had a shorter shaft.
    Are you sure the GX81 is far right?
    I only question because you can't compare a manual converted auto, to a factory manual.
    They have different sized/located holes in the floor.
    What fits perfectly in a manual conversion may not fit in the original (and vice-versa)
    LX80 and GX81 have different part numbers for their lever housings
    Ah, maybe its LX80 I'm thinking is second from left then.
    Definite on the GX81 - JP's old Chaser was a factory manual GX81 and that is what i have used for reference.
    old_school_jap1 - you may have noticed that i was only definite on the GX81, as i have no interest for any of the 4 cylinder engines (4S, 3Y and 2L) so dont know much about them. I gues you have gone off ToyoDIY and oyu will note that the LX80 retainer is only applicable to the LX81, nothing else. The GX81 is also applicable to the SX80 and YX81 - so supports CrUZidas notion that the LX80 is different.
    I was under the impression that the W55 had a shifter position close to that of a T50. Whats it going behind? Also I hope the bellhousing you ordered wasn't a dellows
    Depends what car the W55 came out of ?
    RT142, GX61, no doubt there are some others as well.
    Quote Originally Posted by Sam_Q View Post
    as stated its going behind a 4agze which is going into an ae71 panelvan.
    no niteparts bellhousing was ordered.
    So does everyone think the ma61 w58 would be an alright fit or not?
    Z20- SOLD
    I can confirm that RT142 is the FAR LEFT in the pic above.
    good the niteparts bellhousing seems to be decent from the reports I hear. Why W58 though? wouldnt the ratios be all wrong for something like a 4gze?
    As long as you select the right diff the ratios should be fine.
    Mar 2008
    I have a few w58's, about to install one behind a turbo 20v (also using niteparts bellhousing and 230mm GZE flywheel and clutch), from what i understand the w58 ratios are the closest to the t50.
    and the gx and ma70 shifter positions are both within 1 inch of the factory aeXX position.
    hope some of that helps mate!
    -nath
    Victoria, Mt Macedon
    Just to add to the wealth of info in this thread, GZ20 box is second from the right in the wonderful photo already posted. In an AE86 the shifter comes out right at the back of the shifter hole in the floor. I embiggened the hole by 10mm to be sure.
    Hen
  1. Verifying a w58 gearbox
  2. W58 into TA22
    By fade-e in forum Tech and Conversions
    Last Post: 26-07-2008, 02:42 PM
