if you can find it, it should be in here somewhere...
http://staticfrost.com/manual/90-94%20UCF11%20Manuals/
Hello,
I'm putting UCF10 CF Seats into a non CF Celsior.
Now the CF Seats have a computer on them for the memory seat positions.
On the non CF Passenger seat on the Celsior. The Connector coming from the Seat 3 wires, one of them is a thin green one something for the seatbelt, and the other ones are 2 thick ones, which I believe are positive and Negative that all the seat motors use.
The CF Passenger seat it's connector has those same 2 thick wires, but then has 6 extra wires, they are thin ones, which goto the computer on the seat. Now Since those 2 thick wires are in the same position I assume that it will all work up, so i connected the CF Seat in.
Tilt works, Up and Down works. But headrest adjustment (up and down), and forward and backward (seat rails) do not work. Now by applying 12v to the motor for forward and backward it works, so it's not a bad motor. I'm wondering if anybody has any ideas. Does the computer need power for Forward and Backward to work?
Can anybody direct me to some wiring diagrams for the seats so I can see what wires are what for the seat computer so I can give power to it?
What i'm thinking is that with the CF Seats, the switch must give power to something in the computer, then the computer activates a solenoid to move the motor. That is why I think the computer needs to be powered on to move the seats.
So at the moment is what I want to try is find out which 2 wires to give power to on the seats main connector to give power to the computer, hoping that then all the seat motors will work.
If there is a wiring diagram anywhere or pinouts for the seat control computer that would be good.
Thanks.
specifically here
http://staticfrost.com/manual/90-94%...%29/be-349.pdf
