i think you will probably want a relay to turn on the vvt the solenoid probably draws to much current for the microtechs output.
you don't need a aux idle valve the earlier microtechs didn't have them at all. if you don't have air con etc the only disavantage of not having idle control is that your idle may be a little low when cold and a little high when hot
I think there is a alternator wiring guide on here somewhere from memory the 3 wires are ignition, voltage sense from near the battery terminal and charge light your old alternator might have combined the voltage sense and ignition wires
