Results 1 to 5 of 5
Thread: Crown ms112 diff info required
    Default Crown ms112 diff info required
    I'm looking for instructions on rebuilding/re-assembling a ms112 rear differential, any one have a Toyota guide or the like?
    Craig.
    4agte Sprinter - 11.7 @118mph WSID
    2.45 @ mount panorama
    1.56 @ eastern creek, 1.10 @ wakefield
    1.24 @ oran park GP
    2.00 @ Phillip Island
    Victoria, Mt Macedon
    Default Re: Crown ms112 diff info required
    I have an F series rebuild pdf somewhere (how to assemble the centre and setup crown and pinion), based on an MA61, but may be useable. What do you need it for? Centre specs? Or brake/handbrake?
    Hen
    i need it for the center assembly and how to setup crown wheel and pinion. also i have a feeling i stuffed something up in the wheel bearing/axle seal area (maybe put the seal in the wrong way) as it chewed the seal and i think has damaged part of the bearing, ill try and get some pics after i pull it all out and apart today.
    craig
    1.24 @ oran park GP
    cheers for that, just having a look through it now. i still need the info on the bearings and axle seals as i think the guy who pushed the bearings on for me, dident push them on far enough and as a result the axle seal has been running hard against the bearing, chewing the bearing and the seal.
    1.24 @ oran park GP
  1. Toyota Crown MS63 Custom Wagon Info
    By TheToyman75 in forum Tech and Conversions
    Last Post: 28-09-2007, 01:31 PM
  2. T series rear end diff centre change guide (warning, pics!)
    Last Post: 31-05-2007, 12:57 AM
