Results 46 to 52 of 52
Thread: Solex sidedrafts - High Idle!
  1. #46
    Junior Member Domestic Engineer 71TA22's Avatar
    Carterton
    Default Re: Solex sidedrafts - High Idle!
    Quote Originally Posted by twenty6 View Post
    Oh, and because I don't want to go through this again and it sounds like a common thing to happen, how do you prevent over tightening? Where's the point that they shouldn't be tightened over? Thanks
    Stop as soon as you feel a slight resistance to turning. Dont tighten beyond this.
    Would have liked to have helped with the idle mixure screws but I only have the short ones from earlier carbs.
    Mike
    71 TA22
    My Car
  2. #47
    Nov 2009
    canterbury
    Quote Originally Posted by 71TA22 View Post
    Makes sense
    All good, nothing's fast or easy in this game.
  3. #48
    Jul 2009
    make sure you get a vacuum meter to tune them evenly.
    1985 RT142, 1GGTE,.now with t67-25g
    2009 Ford Fiesta LX
    1970 Ford Cortina MK2 440
  4. #49
    Nov 2009
    canterbury
    I'm back!
    Successfully got the tips out of my bodies using a 'bit' on the inside of the body and a g-clamp to tighten the bit into it pushing it back out through. Thank god.
    Now I have my free holes and brand new idle mixture screws I will install the carbs in a day or two and give this thing another go!
    So now I'm quite worried about tightening these mixture screws since they seem to be easy to break. Will not tighten them past slight resistance
  5. #50
    Excelent thinking twenty6.
    Ask Killa_Ta22 how his now runs and you'll be as happy.
    Regards
    Rodger
  6. #51
    Nov 2009
    canterbury
    Installed them - seem to run all good, don't know how tight the mixture screws are done up because they seem to have resistance the whole way tightening as they are new. Too scared to try find 'fully in' or 'seated'.
    Obviously needs a tune now, backfires slightly or 'pops' every second or so and smells like it's running quite hot?
    Any pointers considering what's previously posted? Could take it somewhere to get tuned but I don't have the money yet and don't want to risk driving it as it is incase how it's running isn't good for the motor.
    Nov 2009
    canterbury
    Think I've tuned the idle pretty well now although any idea why the front idle mixture screw does everything (almost like a speed screw) tightening it goes faster and loosening it reduces the idle, and the other 3 don't really do anything I can hear?
  1. 5sfe Idle Control Valve
    By ra_28 in forum Tech and Conversions
    Last Post: 17-09-2009, 12:05 PM
  2. Using Air-Con after high life cam install
    By CHB in forum Tech and Conversions
    Last Post: 19-07-2009, 10:33 PM
  3. 2JZ weird High Idle problem
    Last Post: 11-05-2009, 07:05 AM
  4. Installing Solex Door Locks
    By RA35GT in forum Tech and Conversions
    Last Post: 21-05-2007, 08:26 PM
  5. High 4AGE Cold Idle
    By toaster in forum Tech and Conversions
    Last Post: 23-10-2005, 03:08 AM
