Results 1 to 14 of 14
Thread: 1jzgte idle issues
    May 2008
    Default 1jzgte idle issues
    Hello Guys
    IVe got a wired Idle problem with my 1JZ.. During cold start its fine...Once warmed up idle is at 1000rpm sometimes its 700rpm.. Ive cleaned out the ISCV and problem still occurs also
    Another thing If I drive the car to operating temp and say turn it off for 15mins and come back to start it will idle at 200rpm and sometimes stall when trying to take off..current fix for this is to tap the go pedel!
    Car drives fine boost fine all the way to 16 psi no cut out also check ECU and no caps buggerd from what I can see
    1992 - JZA70 STOCK - SOLD
    Default Re: 1jzgte idle issues
    Is the ISCV getting power?
    Wilbo's JZA80
    Wilbo's JZZ12
    May 2008
    yep it check that. it does its click click thing when the car turns off
    Know anyone that has an ECU you could try?
    Wilbo's JZA80
    Wilbo's JZZ12
    May 2008
    hmmmm will see. might take the ecu out again and get a closer look. I though the ecu caps issue only affected driving. as it runs great
    Junior Member Backyard Mechanic Azzamk2's Avatar
    western aus
    why where on the subject..what should i check if my cars coldstart isnt working? i have to keep my foot on the accel untill temp rises a little bit. i just converted my cressy to 1j everythings sweet besides that. also i cleaned my ISCV.
    Quote Originally Posted by Azzamk2 View Post
    Check it is powered, in particular by a relay switched by the M-REL output on the engine ECU
    Wilbo's JZA80
    Wilbo's JZZ12
    May 2008
    iscv was pretty fudged in the end didnt do the 3 clicks after turn off! so I modified a 7MGTE one to fit car sits just under 1000 evertime now but issue is still when I start the car after 30-60mins of driving and its still warm it will idle under 500 and stumble...I give the pedel a tap and it raises to 800rpm!! Ive checked the caps and resolderd them as it seems they have been replaced at some stage but dogey solder used
    binge toymoder Grease Monkey
    vic
    did this solve ur issue mate... i have the exact same issue, car just converted, idles low all the time, if i dissconnect the battery and reconnect after 1 minute it starts then idles near 1000 rpm, iscv compensates as it should for a/c and steering and gear selection and continues this as long as i want unil engine is shut off, then if i restart again it will stall and idle very low! ive reset it 5 times and still no permanent results... cleaned iscv, voltage is ok, im wondering if it could be an ecu issue?
    ke70 20v drifta 18psi = 230rwkw
    jzx83 cressida, 14psi = TBA
    May 2008
    this issue still occurs for me. but its gotten worse every now and then when I start it after its been warm and cooled down it will start then stall happens about 3 times then it starts and revs at 200rpm....I thought It was the iscv causing the issue so I modded a 7MGTE one to fit and issue still happend!!
    vic
    i have now replaced all capacitors in the ecu and it still happens... big mystery! really giving me the shits!
    May 2008
    yep same with me all caps are replaced and issue still happens must be a JZ thing
    May 2008
    okay wierd shit going on for example...slowing down for a set of light and revs are 2000rpm....tap pedal and revs drop to 100rpm wtf really annoying me now as it also affects braking car wants to keep on going!!!!
    May 2007
    ide be checking for vaccuum leaks... could be a slight crack in a hose... thus causing the ecu to not know what is going on... have you noticed it running rich at all when these symptoms occur... moreso the low idle than the high...
    when cold the hoses will all shrink slightly and this might be enough to block any holes and keep the idle correct... then once warm the hoses will expand and then your issues appear to start...
  1. 7M-GE idle control valve?
    By orestes in forum Tech and Conversions
    Last Post: 23-12-2007, 08:00 AM
  2. Got a shitty idle with your 4A-GE 20V silvertop?
    Last Post: 19-12-2007, 04:10 PM
  3. shudder at idle post rebuild.
    Last Post: 06-06-2007, 12:59 PM
  4. 1jzgte issues
    By big wad in forum Tech and Conversions
    Last Post: 07-05-2007, 10:26 PM
  5. 100kw in AE82 Idle Issues
    Last Post: 11-01-2006, 06:15 PM
