Results 1 to 2 of 2
Thread: lt12s piggyback
    Jan 2009
    Malaysia
    Default lt12s piggyback
    I'm trying to piggyback the lt12s into my stock Aristo wiring. The stock ecu will go to igniter than to coil. The lt12s ignition output with 6 -ve output.
    1.Should cut the wires inbetween stock ecu to igniter & joing to lt12s ignition output?
    2.For Injectors, Should I remove the stock injector resister & join direct to lt12s injectors output?
    Default Re: lt12s piggyback
    You want to keep the stock ECU to control the auto I assume?
    1) Yes, intercept the wires that go to the igniter (Disconnect from stock ECU)
    You will also need to setup a circuit that generates the IGf (Ignition verification signal) to the stock ECU. The stock ECU won't be happy if it doesn't have this.
    See this thread.
    http://www.toymods.net//forums/showthread.php?p=730738
    2) 2JZGTE Aristo doesn't have injector resistors. Just remove wires to stock ECU and connect to LT12S
    Wilbo's JZA80
    Wilbo's JZZ12
  1. lt12 piggyback wiring
    By Omar in forum Tech and Conversions
    Last Post: 24-10-2009, 12:37 AM
  2. Microtech lt12s to X6 Box Wiring
    By 131OWN in forum Tech and Conversions
    Last Post: 22-01-2009, 06:46 PM
  3. Anyone have a Base map for a LT12s 2jzgte with 800cc
    Last Post: 09-12-2008, 09:04 PM
  4. How To Wire a 1JZ ISCV with MicroTech LT12s
    Last Post: 24-11-2008, 03:15 PM
