Results 1 to 10 of 10
Thread: lt12 piggyback wiring
    Jan 2009
    Malaysia
    Default lt12 piggyback wiring
    Hi All
    I'm new in this forum & need help to get the wiring diagram on Lt12s to 2jzgte Aristo wiring.
    The reason why I'm using piggyback concept due to need to activate the idling, AT trans signal with factory ecu.
    Thanks in advance
    Jan 2009
    Malaysia
    Default Re: lt12 piggyback wiring
    anyone please
    Hi Omar,
    They have a number of wiring diagrams here:
    http://www.microtech-efi.com/support/downloads.html
    They have JZ series ignition diagram listed and the 6 cylinder fuel diagram for LT12S so that should help.
    My KE25 thread
    hey i just finished wiring one of these up in my car to a 1g
    can you explain why exactly you want the signal from the factory ECU? whats the benefit etc?
    Quote Originally Posted by SillyCarS
    Probably to control the features the microtech can't.
    My mate did the same in his STi so the factory ECU could control the idle and a few other things to keep it's factory niceness.
    My KE25 thread
    oh ok
    well in my 30 yr sillycar i think i can go without
    so basically you trick the factory ecu, how do you stop it from making a massive error code list?
    oh ok
    You don't generally (you could though), but because the factory ECU is only controlling the idle valve/motor and idle up for accessories and other ancillaries none of the errors it sees affect their operation in most cars - some of the really modern cars I think it would??.
    Any of the more powerful ECU's negates the need for piggybacking though as they can make everything nice and work properly anyway.
    My KE25 thread
    Jan 2009
    Malaysia
    I'm confused on igniter wiring. For lt12s the output with -ve signal. Plan to cut the wires inbetween stock ecu to stock igniter & join to lt12s wires
    ditch stock igniter.
    get the 6 wires that were going from the igniter to the coils (these are negative)
    connect these 6 wires to the x6 igniter output wires. remember that it is in firing order not 1-6.
    Leave the positive wires on the coils as they will still be ignition switched by the stock loom if you piggy back it.
    QUICKEST 1JZ'S IN OZ
    Jan 2009
    Malaysia
    Chris,
    I'm not using the x6.
    If I'm use back the stock igniter, I should cut the wires from stcok ecu & join it to lt12 ignition out-put (-ve). Is it right chris?
  1. 1jzgte into 88hilux, jzz30 wiring help????
    By hu5tln in forum Tech and Conversions
    Last Post: 28-01-2009, 08:13 PM
  2. 4agte wiring
    By pro-16t in forum Tech and Conversions
    Last Post: 25-08-2007, 11:04 AM
  3. Wiring Experts! Seperating looms for engine swaps?
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 29-08-2006, 07:29 PM
  4. Microleb wiring assistance on 1JZ!!!11oneone!!11(LTX-12)
    Last Post: 23-05-2006, 12:27 PM
  5. 100kW 4AGE wiring diagrams
    By Hen in forum Tech and Conversions
    Last Post: 15-04-2006, 07:03 PM
