Results 1 to 6 of 6
Thread: Anyone have a Base map for a LT12s 2jzgte with 800cc
    Jun 2008
    Default Anyone have a Base map for a LT12s 2jzgte with 800cc
    I'm looking for a base map for a 2jzgte running 800cc injectors to suit a Microtech LT12s more after the fuel side of things then ignition.
    Current Builds
    Soarer Built 1.5jz 425rwkws
    1JZ LPG Build, so far 204rwkw@10psi
    Forum Sponsor Conversion King
    Default Re: Anyone have a Base map for a LT12s 2jzgte with 800cc
    just trim the fuel down by 40% and take it to a dyno.
    its to hard to give accurate fueling figures for different combos,
    things that will affect it =
    cams + cam timing
    brand of injector and the spray pattern which is also affected by the fuel pressure your running
    manifolding on both sides
    turbo selection
    intercooling
    not to mention others but these are the main things.
    Linden
    What is the microtech currently programmed for ?
    You can't 'upload' base maps to Microtech btw.
    I think you'll find he is talking about a cal file ie fuel and ign maps, that way he can start it and drive it.
    depends on what you classify as base maps or setup configs really.
    I'm pretty sure even that isn't uploadable to the Microtech.
    Last I checked the only time anything went from the laptop to the ecu or vice-versa was when you saved a datalog.
    You can back up your maps onto the dongle, and maybe then plug that dongle into someone elses and upload those maps, but last I checked you could not save it to the laptop. They talked about it, but they tend to do a lot of talking. Its been over a year since I checked though.
    true, i havn't played with one in the last 12 months either so it may just be to the dongle but im 90% sure you can upload / download more than just datalogging.
    Meh, i prefer "decent" ecu's so rarely do i have such problems.
  1. 1jz base map for haltech e6x NEEDED!!!!!!!
    By 1.5jzmx83 in forum Tech and Conversions
    Last Post: 10-12-2008, 08:18 PM
  2. 1JZ > 2JZ Map Sensor Upgrade Myth Burried.
    By JZA70 R in forum Tech and Conversions
    Last Post: 14-11-2008, 08:45 AM
  3. Wolf3d V4 base map
    By TheDarkRaver in forum Tech and Conversions
    Last Post: 09-08-2007, 05:27 PM
