Results 1 to 15 of 17
Thread: 22re flatline issue.
    NICE VIBE Backyard Mechanic marvis's Avatar
    Aug 2008
    Default 22re flatline issue.
    So, I put a new head on my car with a head gasket as I blew a head gasket and my other head wasn't as corroded (old one was leaking some water).. Changed injectors also. It has 165-170 on all pots.
    And it's doing this.
    Some people told me it might be the AFM, so I changed it to a 5MGE one, still the same issue...
    It splutters going up slowly, and stops at around 3.5k, you can do it fast, but then it flat lines at the same place. Timing seems sweet.
    I doesn't drive, well it does... But really bad, then it stalls.
    Does anyone know whats going on?
    Thanks,
    marvis.
    West Australia
    Default Re: 22re flatline issue.
    link dont work for me Marvis,
    could be my IE blocking it though as im @ work.
    check it ?
    Mine did the same years back when I had it, dodgy batch of fuel. New fuel filter & pump was needed & it was as good as new. Had fouled the living f*ck out of the plugs as well. Would rev out fine to about 3000rpm and then it was like hitting a wall.
    If in doubt power out
    Aug 2008
    Why would it be doing that right after I did the head though?
    Car been sitting around for a while? Old fuel etc. Things don't necessarily have to be related.
    Junior Member Domestic Engineer ill-minded's Avatar
    May 2006
    was only sitting off the road for a few days. fresh fuel in yesterday. timing has been played with a shitload, to no benefit.
    though, marv, i'm thinking maybe if we did run the fuel dry yesterday when we drove/pushed/towed it round the block, might have sucked up some shit off the bottom of the tank. maybe check fuel filter and those injectors?
    Aug 2008
    Changed injectors, still doing it.
    dirty fuel filter?
    all plugs (TPS, CLT, etc) firmly connected?
    vacuum line to FPR hooked up?
    foreign object stuck in throttle/intake manifold?
    coil properly earthed?
    if you stuffed with the dizzi, did you re-do the connector for the VR sensor? if you swapped the 2 wires around, things will sort-of run but will be quite crapulous.
    Water in the dizzy will do it too.
    Aug 2008
    Fucked valves?
    Team Awesome Carport Converter Pimpin_1JZ's Avatar
    Bunbury W.A.
    If a valve isn't seating properly or it is burnt it will run really rough, as in it won't run on that cylinder. I'm not sure what its doing as my work computer doesn't have sound but I will check it when I get home
    1JZ MZ20 Soarer - 4AGZE KE70 Corolla - 4AGE AE86 - 4AGE KE70
    Is the TPS set properly?
    Have you changed anything in the ignition system?
    Aug 2008
    No i have not.
    I don't know how to set the TPS? I have another here should I swap them?
    Just need to make sure the idle pin is earthed only in idle and open circuits as soon as throttle is cracked.
    Aug 2008
    AH ok cool.
    I'm going to swap the valves etc and see how I go
  1. 22re issue.
    By marvis in forum Tech and Conversions
    Last Post: 23-09-2009, 01:44 PM
  2. 22re crossmember measurements
    By newbien in forum Tech and Conversions
    Last Post: 16-09-2009, 05:33 PM
  3. boost creeping issue..
    By renxun in forum Tech and Conversions
    Last Post: 11-03-2007, 08:32 AM
  4. Boosting Issue
    By Koffee-Black in forum Tech and Conversions
    Last Post: 28-03-2006, 06:33 PM
