Results 1 to 6 of 6
Thread: 22re issue.
    NICE VIBE Backyard Mechanic marvis's Avatar
    Aug 2008
    Default 22re issue.
    I just put another 22RE into my RA65 celica so I can take my time with a 7AGE build.
    I thought it was going to be easy and no issues, but I got this..
    I unplug Number 1 lead and it runs the same.. It is getting an orange spark? Which I'm told it should be blue, but number two is the same.. 3 is a little closer to blue..
    Compression is the following:
    Cylinder 1 , 2 , 3 , 4
    Dry, 200, 180, 185, 160
    Wet, 210, 190, 190, 170
    Any ideas?
    Thanks,
    marvis.
    0402727834 Grease Monkey turbo ke20's Avatar
    Default Re: 22re issue.
    could be a stuffed injector. 1st id make sure its pulsing. Then maybe get them flowed and checked.
    PROWIRE PERFORMANCE WIRING
    Specialising in:
    -Haltech
    -Full Rewires
    -Engine conversions
    -Custom Air Con. Installations
    -Drag, circuit & show car wiring
    Justin Moore
    0402 727 834
    http://www.facebook.com/profile.php?...88667244568569
    I would love to eat a... Domestic Engineer Sagluren's Avatar
    south australia
    number four looks to be down on compression, do a leak down test... so i am asuming it is missing as you have not really told us what is the problem.
    check the leads for high resistance, dissy cap, rotor button. the fact that it is running the same when you disconnected the lead tells you that cly one is not working.
    is there any diffrence when you disconect any other leads?
    try disconnecting injectors while running and see what happens.
    Aug 2008
    If i unplug a lead on the others it stalls. I would assume unplugging the injector on 1 would do nothing?
    Will double check injectors today.
    south australia
    to assume is to make an ass out of you and me.
    Aug 2008
    So I just went to check that the plug from the loom which goes into the injector has a pluse, and it's missing a little metal prong inside it... the other one is geting a pulse.
    I got a cut loom here so I will see what i can patch together.
    FIXED! YESSSSSSS
    I just cut one off from my other loom and put it on....
    Thanks for the help guys
  1. 22re crossmember measurements
    By newbien in forum Tech and Conversions
    Last Post: 16-09-2009, 06:33 PM
  2. Celsior/ 1uz Tacho issue
    Last Post: 11-07-2008, 01:43 PM
  3. boost creeping issue..
    By renxun in forum Tech and Conversions
    Last Post: 11-03-2007, 09:32 AM
  4. 22RE BIG TROUBLES! cutting out mysteriously...
    By ROHANVII in forum Tech and Conversions
    Last Post: 21-07-2006, 09:04 PM
