hi,
im bored and have a spare T18 shell at home, thinking about putting a 22re in it for abit of fun
does anyone know the bolt hole to bolt hole measurements for the 22re crossmember?
i need to know the distance between the four mounting holes for the crossmember
alternatively, has anyone put a 22re into a ke70/ae71/te72/ae86?
I've done 18RG into KE70 and The Witzl is currently doing the same. Mine had steering box (same as TE71) and there were no clearance issues. When I swapped to rack though the starter got in the way. The motor and box setup used was from an RA63 Celica which I think is very similar to the 22RE in terms of sump, mounts etc but you will need to confirm that. Crossmember won't swap.
Callum
