0.015" from the piston crown to the deck surface... your block got deck more than what I'd be confortable with. Normally I try to be between 0.040 and 0.045" but the lowest I'd ever go would be 0.035"... TRD head gasket 0.8mm is well... 0.0315" thick so if your pistons are above deck your well under that minimum... stock headgasket is ~1.2mm thick when compressed (0.047") so you'd be at 0.044" clearance which is pretty within the target area for squish clearance.
