Results 46 to 55 of 55
Thread: 4AGE - Advanced Specs
  1. #46
    Default Re: 4AGE - Advanced Specs
    sorry bring up an old thread but having trouble finding some info that is very relevant to the thread.
    i am looking for piston to head clearances. does anyone know the standard AND does anyone know what the minimum clearence you can run is?
    obviosly the stock clearance is the headgasket thickness but i am not sure if stock the 4age has 0 deck height pistons or if they are proud or under the block deck.
    the engine bloke has found my pistons are sitting 3thou over the deck height so is is a bit worried about the clearence with the TRD gasket
    89' MR2 AW11... His
    00' MR2 ZZW30... Hers
  2. #47
    Aug 2013
    Quebec, Canada
    0.015" from the piston crown to the deck surface... your block got deck more than what I'd be confortable with. Normally I try to be between 0.040 and 0.045" but the lowest I'd ever go would be 0.035"... TRD head gasket 0.8mm is well... 0.0315" thick so if your pistons are above deck your well under that minimum... stock headgasket is ~1.2mm thick when compressed (0.047") so you'd be at 0.044" clearance which is pretty within the target area for squish clearance.
    KE20 1974 <- Sold -> Thread
    AE95 1990 <- 4A-GZE daily driven wagon...
  3. #48
    thanks bermy. so they are normally 0.015 under the deck surface? or is it the other way and above?
    if under that would make standard squish clearence about 0.062" correct or wrong?
    89' MR2 AW11... His
  4. #49
    Aug 2013
    Quebec, Canada
    Exactly, 0.015" under deck so total squish of 0.062" with a stock head gasket.
  5. #50
    oregon
    Quote Originally Posted by bermy View Post
    some disagreement here... if you do the known math...
    center line of crank to block deck is 191mm
    stroke is 77mm
    center to center rod length is 122mm
    compression height is 30.5mm
    stroke 77mm / 2 = 38.5
    191 - 38.5 - 122 = 30.5 = flat deck.......
    Are the numbers wrong????
  6. #51
    Aug 2013
    Quebec, Canada
    I know math pretty damn well, but I also know how to use a thickness gauge... strip a bone stock bluetop or redtop (did it on both), get the piston to TDC and get a thickness gauge on top to have it flush with the deck... 0.015" is what you need. Don't believe me? Try it out
    Oh and compression height is 30.68mm (just measured it on a bluetop 9.4:1 piston) so I guess the deck is a little taller than what we tought...
  7. #52
    0.030" squish is about as low as you'd want to go.
    www.billzilla.org
    Toymods founding member #3
  8. #53
    I didn't even think of this but I measured my bog stock un-machined block with a piston in it. between the dial guage and the digital verniers it looks to be 0.001"-0.002" over the block surface.
    I was using the TRD headgasket on this block and it wasn't contacting the head.
    So my new block that was skimmed the pistons were 0.0024" over as measured by the machinist, and he measured the TRD gasket at 0.032". So its gonna be tight, about a 0.029" squish.
    But that is also using aftermarket pistons that are 38g lighter than the stock ones. I could get the pistons skimmed to give me more room, but not sure if I its worth skimming a few thou off them.
    89' MR2 AW11... His
  9. #54
    Aug 2013
    Quebec, Canada
    Quote Originally Posted by wiso View Post
    Wait, are you measuring the dome there or the edge of the crown? Squish band is around the combustion chamber and both my 9.4:1 bigport and 10.3:1 smallport pistons had the edge of the pistons 0.015" below the deck surface.
  10. #55
    measuring around the outside edge where its flat where you are meant to. i know its not the most accurate tools to measure with it was for an indication to myself. but it certainly is fractionally above the block deck. you can feel a step up when you run your fingers or a straight edge over the block then onto the piston.
    89' MR2 AW11... His
    Last Post: 17-06-2008, 08:53 PM
  2. 4AGE 100kw smallport turbo rebuild
    By BoostBoy in forum Tech and Conversions
    Last Post: 07-05-2007, 10:24 PM
  3. 4age head tension
    By legend in forum Tech and Conversions
    Last Post: 28-03-2006, 07:37 PM
  4. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 04:51 PM
  5. 4AGE, GZE, GTE Specs and Power
    By Dimmy in forum Tech and Conversions
    Last Post: 10-10-2005, 10:59 PM
