Results 31 to 45 of 55
Thread: 4AGE - Advanced Specs
    Default Re: 4AGE - Advanced Specs
    NGK doesn't list a copper version of the spark plug for the 4A-GE..
    it lists BKR6EP-8 which is a platinium plug.. can i just fit the BKR6 plugs? or are they BKR6E-11 ?
    New Zealand
    if the epc is wrong, then i have many many customers using the wrong bolts.
    please, no more PMs!
    Quote Originally Posted by Vios-GT_07
    I've used BCP6ES for years with good results. The last engine needed BCP7ES though, as it ran hotter than a stock engine.
    www.billzilla.org
    Toymods founding member #3
    Robots! dancing robots! Domestic Engineer gearb0x's Avatar
    Number of pistons: 4
    Junior Member 1st year Apprentice HRV-00S's Avatar
    Apr 2007
    So no one has answered the question? Do these torque specs: mains, con rods, head, cams etc the same for the gze version as I've been searching for ages but can't find any info. Maybe I'm just stoopid but my 4agte is in pieces and almost ready to go back together so I'm starting to get desperate but don't want to start a new thread if it has been covered before. If someone could point me in the right direction I would be forever grateful.
    Cheers Harvo
    New Zealand
    yes the torque settings are the same
    Apr 2007
    Quote Originally Posted by Mr Revhead
    Too easy, Thanks for that it will make life a lot easier.
    I also need to know if the piston to bore oil clerance is 0.12 - 0.14mm (gze) as I'm chasing a set of Toyota .50 oversized pistons. Is this the right clerance (was found on here some where) for the over sized pistons?
    ps: Mr Revhead, I've sent you an email regarding some parts for my re build
    Cheers Harvo
  8. #38
    New Zealand
    i dont have the piston specs handy, but someone on here has posted them straight out of the manual.
    no doubt ill get it monday!
  9. #39
    Chiba
    Does anyone know the length of the exhaust ports (from the centre of the valve to the exhaust port gasket face)?
    I need it to help me design some custom tuned headers.
  10. #40
    Hoppers Crossing
    adding to this
    welchplugs = 6 x 35mm and 1 x 40mm
    as the link above is dead
    headbolt loosening sequence
    IN 03 07 09 06 02
    EX 01 05 10 08 04
    tightening sequence
    IN 08 04 02 05 09
    EX 10 06 01 03 07
  11. #41
    Hoppers Crossing
    bugger it
    and
  12. #42
    Hoppers Crossing
    NB : This book was published in Aug 1983. Pub No 36230E
    Note the torque settings for the head are for VERY VERY VERY early 4AGE bigport
    The later 100kw as described in other threads and 29nm then 90 deg and 90 deg again.
  13. #43
    Dec 2008
    Shropshire
    Quote Originally Posted by Black
    Cylinder Block
    Type: 4cyl inline (obviously )
    Material: Cast iron
    Cyl Bore diameter: 81.00-81.03mm. Limit: 81.23mm
    Bore Taper and ovality limit: 0.02mm
    Cyl head face distortion limit: 0.05mm
    Pistons and Rings
    Piston diameter: 80.89-80.92mm
    Oversize piston avail. :0.50mm
    Piston oil clearance: 0.10-0.12mm
    Number of rings:
    Compression: 2
    Oil control: 1
    Crankshaft and Bearings
    Main bearings: 4
    Crankshaft end float: 0.02-0.22 mm Limit: 0.30 mm
    Main bearing journal diameter: 47.982 - 48.000 mm
    Main bearing oil clearnace: 0.015 - 0.033 mm Limit: 0.10 mm
    Main bearing journal and crank pin taper and ovality limit: 0.02mm
    Crankshaft runout limit: 0.06 mm
    Main bearing undersize available: 0.25mm
    Crank pin diameter: 41.985 - 42.000 mm
    Crank pin bearing oil clearance: 0.020 - 0.051 mm Limit: 0.08 mm
    Crank pin bearing undersize available: 0.25 mm
    Connecting rod endfloat: 0.15 - 0.25 mm Limit: 0.30mm
    Cheers Black
    Err, just looking at these specs, haven't we lost a main bearing somewhere? *5* main bearings, not 4, of course.
  14. #44
    Chiba
    For the Smallport:
    Intake runners measure at 96mm from gasket face to valve seat.
    Exhaust runners measure at 82mm from gasket face to valve seat.
    Exhaust will be the same for bigport, intake should be close enough.
    Could be handy for those designing exhaust or intake manifolds.
  15. #45
    oregon
    Quote Originally Posted by takai View Post
    Just creating this thread so that a lot of the less commonly known specs can be noted down for future reference.
    Measured up the head on my spare smallport the other day and here is some of the bits i measured:
    Head capacity: 39cc
    Cylinder spacing (center to center): 89mm
    Feel free to post other measurements as well.
    I know... I know a bump from hell.......
    but the info is incorrect.... at least a stock chamber is 36cc... NOT 39cc. I've confirmed this on multiple occasions
    now... as far as the word "capacity".... I have opened a stock chamber as far as 39cc... so it is kinda accurate... a stock chamber can be opened up to 39cc, but stock uncut is 36cc
    Last Post: 17-06-2008, 08:53 PM
  2. 4AGE 100kw smallport turbo rebuild
    By BoostBoy in forum Tech and Conversions
    Last Post: 07-05-2007, 10:24 PM
  3. 4age head tension
    By legend in forum Tech and Conversions
    Last Post: 28-03-2006, 07:37 PM
  4. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 04:51 PM
  5. 4AGE, GZE, GTE Specs and Power
    By Dimmy in forum Tech and Conversions
    Last Post: 10-10-2005, 10:59 PM
