Results 16 to 20 of 20
Thread: ta22 t50 short shift
    Junior Member 1st year Apprentice Patric's Avatar
    Default Re: ta22 t50 short shift
    Good work Frank. Really supprised to see photos on the net so soon. We only took those photos yesterday.
    Apr 2011
    Quote Originally Posted by gearb0x View Post
    Ahh bummer, if you want to do something a little easier then
    EARLY T-18 (79 maybe 80 model, chrome bumpers but check. I know for sure the plastic bumper model had a 22 spline output shaft) are 20 spline with a T bellhousing, will swap right in
    Just to clarify, those t50s are a 20 spline and they have the 22 spline style shifter, so it has the further back shifter position? And therefore wont fit into a ta22 or in my case ke25 without mods to the shifter hole in the gearbox tunnel.
    Robots! dancing robots! Domestic Engineer gearb0x's Avatar
    that is correct
    Junior Member Backyard Mechanic scottsta22's Avatar
    Heres the answer to your prayers, I had one custom made about 2 or 3 yrs ago by Torrie racing in NZ, you can find him on ebay he makes the short shifters for the
    W50 box and after a lot toing and froing with prototypes and mucking around with the housing etc we finally got it sorted. There was one problem though which I fixed myself.
    If you have a GT console in 1st gear the shifter was way too close to the upper section of the console so I took it to an engineering place with my standard shifter and got them to heat & bend it to the same as the original, it works fantastic, no slop in it at all. After all the time it took and mucking around I'm glad I did it.
    In conversation he did say he was making a couple more to see how they'd go. I did mention that I was in the process of getting a prototype made in the Classic Celica thread at the time but didn't get much interest at that stage.
    He is also on facebook under TRS shifters and is a really nice bloke so its probably worth getting in touch with him and seeing if he has any left or can make more.
    Scott
    Forgot to mention a big plus for me is with the short shifter I no longer need to lift the stick to put it in reverse.
